Two Quick Questions Regarding Lasers - I hope this is the right place to ask
  • Thread starter Thread starter Umbra Lupis
    Lasers
Umbra Lupis
In my math class we were given an assignment to model lasers, we have been given equations, and terms have been somewhat defined, but I do not know what the following terms are when relating to a laser. Any help in defining them would be awesome!
What is:
Mirror Transmission,
Pump Strength?
Thanks for your time and any help you can provide!
PS:
For those interested the equations given were:
dn/dt = GnN - kn
dN/dt = -fN - GnN + P
Where n is the number of photons, N is the number of excited atoms, G > 0 is the
gain coefficient for stimulated emission, k > 0 is the decay rate due to loss of photons by mirror transmission, scattering, etc., f > 0 is the decay rate for spontaneous emission, and P is the pump strength.
Mirror transmission is the probably the probability that a photon will exit the laser when it hits the mirror. Pump strength is probably the rate at which the pump excites the atoms. I am just using your equations to make these guesses.
turin is correct. You can also think of mirror transmission as the percentage of power in an incident wave that is transmitted (vs. being reflected) by the mirror.
Thanks guys!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
