nearc said:
thanks for the reply, while i am working on learning the math of GR, I'm not at point yet where i can work everything out for myself, do you have a worked math example of what you propose or something similar?
if it is helpful we can add some more constraints we can allow the two ships to be sufficiently far apart such that they will take more than 1 billion years before they collide [in the internal reference frame from a stationary external point over 31 billions years]
I have half a worked example. But I'm not sure how much help it will be (asides from missing the most interesting part). More below.
But first, I'll suggest something simpler to get you ready. Have you looked at the electrostatic interaction between two moving charged particles as a clue?
You'll see that the transverse electric field changes - it intensifies. But there is a counterbalancing magnetic force. And the "force" isn't an invariant in this case, but the four-force is.
So, you might start thinking about the gravitational case, in a similar manner.
Onto the gravitational case:
The half-worked example I have is an outline of computing the Riemann curvature tensor of a moving observer.
But I've only computed part of the curvature tensor.
What you'll need to understand the half of what I've got is:
1) Enough familiarity with the Riemann tensor to understand the interpretation of it as a "force" per unit distance, a tidal force.
1a) It's also helpful to understand the limitations of this approach - specifically it's not the "real" definition of the Riemann, it just works very well under reasonable accelerations. We don't have any accelerations in this problem at all, so that's not an issue. Also, rotations (even slow ones) are not handled by this interpretation.
1b) The whole reason we use the Riemann is because the "Force" doesn't really transform like a tensor, and the Riemann does. So some care is advised! The goal is to get the Riemann "plugged into" your intuition. But if you're just starting, this might be hard/impossible. I'd recommend MTW ("Misner, Thorne, Wheeler - Gravitation") for more details on the "tidal force" interpretation of the Riemann, if you're ready for it - though they won't point out its limits.
2) The ins-and-outs of Orthonormal frame fields (which are a non-coordinate basis). A simple example - in polar coordinates you might have coordinates ##r## and ##\theta##. You might also have unit vectors in the associated directions, typically called ##\hat{r}## and ##\hat{\theta}##. Those vectors, because they are orthonormal, are handy to work with - they are called a non-coordinate basis. A coordinate basies would be ##\frac{\partial}{\partial r}## and ##\frac{\partial}{\partial_{\theta}}##. Notation varies, the "hat" notation is used by MTW, though.
I'd guess I loose about 95% of the readers every time frame fields come up :-(.
For the posts
https://www.physicsforums.com/showpost.php?p=689706&postcount=2
https://www.physicsforums.com/showpost.php?p=690472&postcount=10 for a sketch
What's missing from the calculation is the part of the Riemann tensor that's analagous to the magnetic force / magnetic field in the electrostatic case. This is sometimes known as the magnetogravitic tensor. See
http://en.wikipedia.org/wiki/Bel_decomposition
Unfortunatley, this is probably *the* key thing you really need.
The process of "decomposing" the Riemannn in this way is known as the Bel decomposition. The Bel decomposition is extremely helpful in understanding things, but it's an advanced topic and hard to find a good discussion about.
THe original papers are behind a paywall in French. There is a *very* short and not particularly detailed discussion in MTW's gravitation, which doesn't actually use the name "Bel Decomposition" so its hard to find.
One other thing - there is a new feature here in the strong field. THis is the "topogravitic" part of the tensor. You may or may not want to interpret this as a force. But you may need this to get all the numbers to finally balance out and fully understand the motion.
And another thing: It may or may not be possible to simplify this discussion enormously by considering the weak field. I've always thought that the terms involved were second order, making the linear approach a bit "iffy", but I should revisit that.
