I Two stationary values for an action
  • I
  • Thread starter Thread starter Happiness
An action derived from a Lagrangian can have multiple stationary values if a physical system has more than one real path through phase space. However, this raises questions about Liouville's theorem, which asserts that the density of system points in phase space remains constant over time. If one point in a simply connected volume has two trajectories, it could disrupt the volume's density or topology, contradicting Liouville's theorem. Thus, if a point has a unique trajectory, all neighboring points must also have unique trajectories. Ultimately, while multiple stationary values of the action are theoretically possible, they do not necessarily imply a violation of Liouville's theorem.
Happiness
Is it possible for an action (the integral of a Lagrangian) to have more than one stationary value? Why or why not?
If there are more than one real path through which the physical system can move in phase space (q,p) then it can have multiple stationary values -but i have yet to see an example of the same
drvrm said:
If there are more than one real path through which the physical system can move in phase space (q,p) then it can have multiple stationary values - but i have yet to see an example of the same
If there are multiple stationary values, then a point in phase space (q,p) may have multiple trajectories. Does that violate Liouville's theorem: the density of system points in the vicinity of a given system point traveling through phase space is constant with time?
And Lioville's theorem, I think, also states that a "volume" of system points in phase space must maintain its topology under time evolution. So a simply connected volume must remain simply connected. Assume all except one point P in a simply connected "volume" has exactly one trajectory, while point P has two (say, path A and path B). Only one path (say, A) allows the volume's density and topology to remain unchanged, while the other path (B) either increases the density of the volume (if the path ends within the volume) or makes a hole in the volume (if the path ends outside the volume). Using the same argument, we conclude that if a point has exactly one trajectory, then all its neighbouring points must have exactly one trajectory.
EDIT: Liouville's theorem shows that if a system A in an initial state X has exactly one trajectory determined by a set S of equations, then the same system A but in any other initial state Y must also have exactly one trajectory determined by the same set S of equations. But it does not show that there could only be one stationary value of the action. It does not show that the Hamilton's principle solves for a unique set S of equations.
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
