Two strings spinning rock- tension
The problem involves determining the maximum speed at which a 670 gm rock can spin between two strings without breaking them, given that each string can withstand a tension of 24 N. The radius of the circular motion is calculated to be 32.187 cm using the Pythagorean theorem. The equation N = m (v^2 / r) is applied, leading to the conclusion that the initial setup may require adjustments to account for the components of tension in the strings. Specifically, the tension must be analyzed to separate the centripetal force from the tension acting on the strings. The discussion emphasizes the need for a correct understanding of the forces involved in circular motion.
TG3
A string 44 cm long will break under a tension of 24 N. Two such strings are tied to a 670 gm rock, their ends 60 cm apart. The rock is spun between them. What is the maximum speed it can spin before the string breaks?
(Using pythagorean theorem, you can determine the radius of the circle is 32.187. I'll save you the hassle.)
N = m (v^2 / r)
48 =.67 x (v^2 / 32.187)
71.64 = v^2 / 32.187
2305.934 = v^2
48.020 = v
I have a suspicion that the problem is conceptual: am I supposed to use sine or cosine somewhere?
Draw the diagram of forces and you'll see that the tension in each string can be divided into two components. One component supplying the centripedal force to the stone, and one pulling on the other string.
So your line
needs modification.
