Ultraviolette Catastrophy -Intensity causes melting of objects?
  • Thread starter Thread starter christian0710
    Melting
The discussion centers on the misunderstanding of the ultraviolet catastrophe, clarifying that it is not the intensity of light that causes melting of objects but rather the temperature, which affects molecular kinetic energy. The ultraviolet catastrophe arises from classical electromagnetic theory and the equipartition theorem, which incorrectly predicts infinite intensity as frequency increases. This discrepancy highlights the inadequacy of classical physics in explaining black-body radiation. The conversation emphasizes that the issue lies more with the equipartition theorem than with classical electromagnetic theory itself. Understanding these concepts is crucial for grasping the historical context of the ultraviolet catastrophe.
christian0710
Hi,
Is it correctly understood that it's the intensity of light that causes melting or heating of objects and not frequency or vice versa? I'm trying to understand the ultraviolette catastrophe (what the problem was) and according the the equation for intensity (given below) frequency increases exponentially, when intensity increases, so is this the poblem scientists were facing: if a black body radiates light at high intensity it would produce a frequency that was high enough to melt objects and as the intensity increased the frequency would go to inifnity?
I = (2*f*Kbb*T)/c^2
Science news on Phys.org
No.
Frequency of light is not what melts objects. Objects melt roughly due to being high enough in temperature such that the kinetic energy of the molecules of the solid can overcome the inter-molecular forces holding the object in its solid state.
The ultraviolet catastrophe has nothing to do with melting objects. It's that the prediction of black body radiation intensity by Rayleigh and Jeans predicts an infinite total intensity due to the intensity frequency relationship diverging as the frequency grows. It was an experimentally known fact that this is obviously wrong.
christian0710 said:
Hi,
I = (2*f*Kbb*T)/c^2
The ultraviolet catastrophe results from classical electromagnetic theory and from the equipartition theorem of the classical kinetic theory (statistical mechanics). According to classical EM theory, the number of vibrational modes (analagous to classical degrees of freedom) of an EM wave in a black-body cavity resonator should be proportional to the frequency^2. According to the equipartition theorem, all modes should have the equal energy. So the rate at which energy is radiated by the black body should increase rapidly with frequency (ie in proportion to the number of vibrational modes which is proportional to the square of the frequency). Since this is not observed, it is apparent that classical physics is not adequate to explain black-body radiation.
My sense is that the ultra-violet catastrophe is more a failure of the equipartition theorem than of classical EM theory.
AM
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
