kof9595995
- 676
- 2
Show that in order to be able to determine through which slit a double slit system each photon passes without destroying the double silt diffraction pattern, the condition
\delta y\delta {p_y} \ll \frac{h}{{4\pi }}
must be satisfied. Since this condition violated the uncertainty principle, it can not be met
d\sin \theta = \lambda
\sin \theta = \frac{{\delta {p_y}}}{p}
\lambda = \frac{h}{p}
In order not to destroy the pattern, the angle should not be large enough to shift one maximum to its adjacent maximum. So \sin \theta \ll \frac{\lambda }{d}, and then we have
\frac{{\delta {p_y}}}{p} \ll \frac{\lambda }{d}
To figure out which slit the photon passes through, we must have
\delta y \ll \frac{d}{2}
Combine these two and use de broglie's relation \lambda = \frac{h}{p}
We can get
\delta y\delta {p_y} \ll \frac{h}{2}
But it seems to me the extra 2\pi just comes out from nowhere. I'm really pulling my hair off on this quetsion
