Uncertainty Calculation for Lab Report: Methods & Comparison
In summary: If so, then you should calculate them using the uncertainty propagation formulas. Otherwise, I'm not sure what you are asking.
omoplata
327
I'm trying to write a lab report.
I've taken some measurements several times and have calculated the results and the systematic uncertainty for each set of measurements. i.e. I have [tex]x_{i}[/tex] s, which are the results, and I have [tex]\Delta x_{i}[/tex] s, which are the systematic uncertainties, calculated using uncertainty propagation formulas and the systematic uncertainties of the measurements.
I need to take the average of [tex]x_{i}[/tex] s. How do I calculate the error for that?
I can think of two methods. I don't know which is correct.
Method 1: Calculate it using uncertainty propagation formulas and [tex]\Delta x_{i}[/tex] s.
Method 2: Use the standard deviation of the [tex]x_{i}[/tex] s as the uncertainty.
Which is correct?
Which is correct?
If all of your xi's are sampled from the same distribution, then you can use the standard deviation of the mean formula ... just take your estimate for the standard deviation of the distribution (i.e. your calculated standard deviation for a single value), and divide by the square root of the number of trials.
Thanks for the reply,
I don't know if it's from the same distribution. [tex]x_{i} = \rho [/tex] where I used [tex]V=I R[/tex] and [tex]R = \frac{\rho l}{A}[/tex] for the calculation of the resistivity of the same semiconductor sample at different lengths and cross sections. If it was an ideal sample and measurement I'm supposed to get the same resistivity [tex]\rho[/tex]. So I guess there would be NO expected distribution?
What should I do?
What should I do?
All real measurements sample a distribution, even if the quantity being measured is completely precise (which it usually isn't), your measurement technique will always have an associated uncertainty. The term "distribution" just refers to the range and relative probabilities of possible values for the measurement. Typically we assume the values will be normally distributed around a mean value, which we then take to represent the "real" value of the quantity to be measured. The standard deviation as calculated from a finite number of measurements, gives you an estimate of how broadly the possible values are distributed around the mean value. Finally, since you normally estimate the mean of the distribution as well (by averaging a finite number of values), the standard deviation of the mean (as I described it above), gives you an estimate of by how much your calculated mean is likely to deviate from the true mean of the underlying distribution that you are sampling.
In your case, since the theory tells you to expect that the resistivity of the sample is constant, you are free to assume that all of your measurements are sampling the distribution of possible values of the resistivity. In other words, you should be able to use the standard deviation of the mean to estimate the uncertainty of your mean value.
Great! I'll use the standard deviation as the uncertainty then. Thanks a lot for the help!
But then did I calculate the systematic uncertainties, [tex]\Delta x_{i}[/tex] s for nothing?
Should I at least use the uncertainty propagation formulas to calculate the final systematic uncertainty for the average and see which one is larger(between the standard deviation and the propagated systematic uncertainty), and use the larger one for the uncertainty? Or should I just ignore the calculated [tex]\Delta x_{i}[/tex] from here onwards?
Note that I said standard devation of the mean .. that is different from just standard deviation, as I explained in my first post in this thread.
I am not sure what you mean by the systematic uncertainties ... do you mean the deviations of the individual resistivity values from your calculated mean? The term "systematic uncertainty" is typically used to refer to something else entirely.
You should definitely use the propagation rules to convert the uncertainties in the measured values (which I guess are voltage, length and area?) in your experiment, into the uncertainties for the calculated values (i.e. resistivity).
So, the standard deviation of the mean is equal to [tex]\frac{ \sqrt{ \frac{ \sum_{i=1}^{N} ( \overline{x} - x_{i} )^2 }{N} } } { \sqrt{N} }[/tex] ?
What I meant by systematic uncertainty was, I took the least possible measurements (which depends on my measuring instruments) for [tex]V_{i}[/tex], [tex]I_{i}[/tex], [tex]l_{i}[/tex] and [tex]A_{i}[/tex] as [tex]\Delta V_{i}[/tex], [tex]\Delta I_{i}[/tex], [tex]\Delta l_{i}[/tex] and [tex]\Delta A_{i}[/tex] (I call them "systematic uncertainty of the measurements"), and then I applied the error propagation formulas to the final equation [tex]\rho_{i} = \frac{V_{i} A_{i}}{I_{i} l_{i}}[/tex] to find [tex]\Delta \rho_{i}[/tex] (I wrote [tex]\rho_{i}[/tex] as [tex]x_{i}[/tex] and [tex]\Delta \rho_{i}[/tex] as [tex]\Delta x_{i}[/tex] in my original post). Here [tex]\Delta \rho_{i}[/tex] is what I call the "propagated systematic uncertainty".
So which should I use for the final uncertainty of resistivity?
1. Standard deviation of the mean?
2. Final propagated uncertainty for the mean resistivity?
3. The larger of the two?
4. Or the two combined in some way?
Sorry about my difficulty in understanding this. I don't know much statistics/error analysis.
OK, I have found out from "Data Reduction and Error Analysis for the Physical Sciences" by Bevington and Robinson that standard deviation of the mean is,
[tex]\sigma_{\mu} = \frac{ \sqrt{ \frac{ \sum_{i=1}^{N} ( \overline{x} - x_{i} )^2 }{ N - 1 } } }{ \sqrt{ N } } [/tex]
I still don't kow how to calculate the final uncertainty.
Notice that the quantity in the numerator is just the standard deviation for a single measurement, as I said in my first post.
As you surmised, you can calculate the final uncertainty in one of two ways. You can estimate mean values and standard deviations for your measured quantities and use error propagation to convert those into a mean value and standard deviation for the resistivity. Then dividing by sqrt(N) will give you the standard deviation of the mean.
Alternatively, you could calculate the resistivity for each individual trial, and then use those values to estimate the mean, standard deviation and standard deviation of the mean for the resistivity.
I recommend doing it both ways, and then checking your results. I think the two estimates should agree with each other fairly well if you are doing everything correctly, so I don't think it matters much which one you use. Of course the most conservative way is to estimate both ways and report the largest value. If I recall correctly, I believe the first method generally yields more conservative (i.e. larger) estimates of the uncertainties, except perhaps when you are dealing with small numbers of trials, so that is the one that is typically used.
What is uncertainty calculation?
Uncertainty calculation is a process of measuring and quantifying the amount of error or uncertainty associated with a particular measurement or experiment. It involves identifying and evaluating all possible sources of error and determining their combined effect on the final result.
Why is uncertainty calculation important in science?
Uncertainty calculation is important in science because it helps to ensure the accuracy and reliability of experimental results. By understanding and accounting for the sources of error, scientists can have more confidence in their findings and make more informed conclusions.
What are the different types of uncertainty?
There are two main types of uncertainty: random (or statistical) uncertainty and systematic uncertainty. Random uncertainty refers to the inherent variability in a measurement or experiment, while systematic uncertainty is caused by factors that consistently affect the results in a specific direction.
What is the difference between accuracy and precision?
Accuracy refers to how close a measured value is to the true or accepted value, while precision refers to how close multiple measurements of the same quantity are to each other. In other words, accuracy measures correctness while precision measures consistency.
How is uncertainty expressed?
Uncertainty is usually expressed as a range or interval around the measured value, often with a specified confidence level. This range is often represented by the standard deviation or the margin of error, and can be reported as a plus/minus value or as a percentage of the measured value.
  • Other Physics Topics
