Uncertainty principle - just want to check my method
The discussion focuses on estimating the kinetic energy of a quark confined in a proton using Heisenberg's uncertainty principle and kinetic energy equations. Participants clarify how to derive the uncertainty in momentum (Δp) from the uncertainty in position (Δx) and discuss whether it is appropriate to express the change in kinetic energy (ΔT) in terms of Δp. It is confirmed that using the relation ΔT = Δp²/(2m) is acceptable for this calculation. There is also a mention of an alternative method involving differentiation, but the consensus leans towards the simpler approach. The thread emphasizes the importance of understanding when to apply different methods in quantum mechanics calculations.
quantumlolz
Estimate the kinetic energy of a constituent quark of mass 300 MeV/c^2 confined insdide a proton of radius 1 fm
Heisenberg's uncertainty principle \Delta x \Delta p \approx \hbar (1)
Kinetic energy T=\frac{p^2}{2m} (2)
So we've got \Delta x. So we can rearrange (1) to get \Delta p
Then we need to use (2). Is it OK to just say \Delta T = \frac{\Delta p^{2}}{2m}
Alternatively could we use the relation that delta T = dT/dp delta p but then we'd need to know p as well. And how would we then use this to get T?
This should be easy, but I never know when to use the second method using differentiation and when not to. Cheers.
That is perfectly fine.
