Uncertainty relation demonstration
andresordonez
HI, I will not used the template provided since this is not a textbook problem. It's a problem I have with a demonstration in Quantum Mechanics Vol 1, Cohen-Tannoudji
Complement C III
[Q,P] = i \hbar
Consider the ket:
|\phi \rangle = (Q +i\lambda P)|\psi \rangle
where \lambda is an arbitrary real parameter. For all \lambda, the square norm \langle \phi | \phi \rangle is positive. This is written:
\langle \phi | \phi \rangle = \langle \psi | (Q - i \lambda P)(Q + i \lambda P) | \psi \rangle
=\langle \psi | Q^2 | \psi \rangle + \langle \psi | (i \lambda Q P - i \lambda P Q) | \psi \rangle + \langle \psi | \lambda ^2 P^2 | \psi \rangle
=\langle Q^2 \rangle + i \lambda \langle [Q,P] \rangle + \lambda ^2 \langle P^2 \rangle
=\langle Q^2 \rangle - \lambda \hbar + \lambda ^2 \langle P^2 \rangle \geqslant 0
The discriminant of this expression, of second order in \lambda, is therefore negative or zero:
\hbar ^2 - 4 \langle P^2 \rangle \langle Q^2 \rangle \leqslant 0
and we have:
\langle P^2 \rangle \langle Q^2 \rangle \geqslant \frac{\hbar ^2}{4}
I don't understand why the discriminant must be negative or zero for \lambda to be real. As far as I know, if you have:
a x^2 + b x + c = 0
with a, b, c reals, then:
x = \frac{-b \pm sqrt{b^2 - 4 a c}}{2 a}
and x is real if:
b^2 - 4 a c \geqslant 0
In this case:
a = \langle P^2 \rangle
b = -\hbar
c = \langle Q^2 \rangle
so the discriminant should be positive or zero instead of negative or zero right?
If f(λ)=aλ2+bλ+c ≥ 0 for all λ, then its graph either lies completely above the λ axis or is tangent to the axis, so that it has, respectively, no (real) roots or just one.
Right, thanks!
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
