Originally posted by jakrabb
I am trying to understand how the doppler effect was used when determining that the other stars were moving away from us. I get that the spectral lines observed are shifted and by examining that data we can calculate how fast its moving and if it is towards or away from us. could anyone elaborate on this? can we actually tell a direction; is the margin of error large or small? ... i guess i just need more info to comprehend it all..
lines are shifted by two effects----ordinary doppler due to relative motion (visible e.g. in spectra of nearby stars) and cosmological redshift due to expansion of space (visible e.g. in spectra of distant galaxies)
the rate space is expanding has changed over the course of time and so the cosmological redshift cannot be ascribed to anyone particular radial velocity but must be related to how much space has expanded during all the time the light has been in transit
it may help to think of a distant galaxy as sitting still in the space around it---but that neighborhood of space is getting farther away from us
the standard formula for the cosmological redshift (as opposed to doppler) is in terms of a(t
emit) and a(t
rec) the scale-factor (indicating "size of universe" or "average distance between galaxies") at the time the light was emitted and at the time it was received.
1 + z = a(t
rec)/a(t
emit)
(see Eric Linder's online "cosmology overview" for this, or any of a bunch of other sources findable on google)
DOPPLER shift formula on the other hand is primarily for things in the same coordinate chart---same local coordinates----so that there is a well-defined radial velocity.
For things in the same locale, Special Relativity applies and we have the SR Doppler formula
1 + z = sqrt ((1 + beta)/(1 - beta))
here beta = v/c, the radial velocity expressed a fraction of light
this SR Doppler formula is approximately the same as a much simpler one without the square root:
1 + z = 1 + v/c
z = v/c
The approximation is fine as long as v/c is small, like 0.01 or less.
The sideways component of velocity (as contrasted with the radial component which Doppler indicates) has to be determined by different means, like noting a star's change in position over the course of years.
Any of this what you wanted?
