Understand the Mystery of MgO: Magnesium + Oxygen Chemistry
  • Thread starter Thread starter Faiien
    Chemical Formulas
The discussion centers on the chemical reaction between magnesium and oxygen to form magnesium oxide, represented by the equation Mg + O2 = MgO. A participant questions the absence of one oxygen atom, suggesting it should be MgO2. The response clarifies that the formula is correct as written, explaining that magnesium loses two electrons (Mg^+2) while oxygen gains two (O^-2), resulting in the neutral compound MgO. It emphasizes the importance of balancing the reaction, noting that the correct balanced equation is 2Mg + O2 -> 2MgO, ensuring that the number of atoms for each element is equal on both sides of the equation. The conversation concludes with acknowledgment of the clarification provided.
Faiien
So I'm taking chemistry again after a five hear hiatus from the topic and I would really appreciate an explanation on a certain formula.
magnesium +oxygen forms magnesium oxide
Mg+O2=MgO
My question is, what happened to the 1 of the oxygen atoms?
Shouldn't it be MgO2?
Chemistry news on Phys.org
Mg+O2=MgO
you shud write Mg and O in separate ion form = Mg^+2 + O^-2 = so, magnesium gives 2 electrons and oxygen takes 2 elctrons, the 2's cancel out = MgO. You have to realize that the end molecule has a net charge of zero, its electrically neutral.
Mg+O2=MgO
All three formulas are correct. However, this is just a skeletal reaction equation, that is - it contains correct formulas, but it is not yet correct otherwise.
No, formula is correct and it shouldn't be modified. Where is the oxygen? Reaction should be balanced - that is, you should add stoichiometric coefficients so that number of atoms of all elements on both sides is identical:
2Mg + O2 -> 2MgO
Now everything is OK.
2Mg + O2 -> 2MgO
ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator
www.ph-meter.info - ph meter, ph electrode[/QUOTE
Yes its right. But i was not sure what you were asking in the original question:)
Me?
Haha, ah I see now, thank you everyone.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
