Understanding alarm clock description
  • Thread starter Thread starter ehrenfest
    Clock
The SB200ss clock features dual power and dual time capabilities, allowing it to operate on both 110V and 220V power supplies, which are common in different countries. It includes a switch to toggle between 50Hz and 60Hz, ensuring accurate timekeeping regardless of the voltage used. This means that the clock can be safely plugged into standard outlets in the United States, which typically provide 110V. The dual time feature refers to the clock's ability to maintain proper time across different frequency settings, preventing any timekeeping issues that could arise from using the incorrect voltage or frequency.
ehrenfest
https://www.amazon.com/dp/B000EX7LNM/?tag=pfamazon01-20
Dual power and dual time features. Our SB200ss clock comes with a 110 volt power supply, will work with 220 volt transformers. Clock also has two switches one allowing user to switch from 50Hz 110 volts to 60Hz 220 volts. This feature keeps proper time with 110 or 220 volts. Another switch allow user to select 12/24 hour time.
Can someone please explain to me what this means? What is "dual power and dual time"? Will it plug into my outlet or not (I have the type of outlet that is ubiquitous in the United States)? What is meant by "keeps proper time with 110 or 220 volts"?
Computer science news on Phys.org
Hi ehrenfest! :smile:
It just means that in some countries the mains power supply is 220V instead of 110V, and 60Hz instead of 50Hz.
The different Hz would affect the rate of the clock (so "dual time"), and the different V would damage the thing!
This item has a switch which changes it safely and accurately from one type to the other. :smile:
I see now! So it has nothing to do with an extra spacetime dimension like I originally thought. :smile:
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
