Understanding Complex Plane Regions: Solving Equations and Graphing Circles
The discussion revolves around shading regions in the complex plane based on given equations involving complex numbers. The specific equations under consideration are z - Conjugate[z] = 4 and 1 + z, where |z| = 1.
  • Participants explore the implications of the equation z - Conjugate[z] = 4, questioning the nature of the solutions and the representation of y as a real number. There is also discussion about the interpretation of |z| = 1 and how it relates to circles in the complex plane, with some participants questioning the validity of transforming the equation into a disk representation.
Some participants have provided insights regarding the nature of the solutions, particularly noting that z - Conjugate[z] = 4 has no solutions in the complex plane. Others are seeking clarification on the reasoning behind this conclusion and the implications for the regions being shaded.
There is an ongoing examination of the definitions and properties of complex numbers, particularly regarding imaginary components and their relationship to real numbers. Participants are also considering the conditions under which certain inequalities apply in the context of the complex plane.
goojilla
Shade each region in the complex plane. Justify your solution.
1) z - Conjugate[z] = 4
2) 1 + z, where |z| = 1
So for my attempt for 1 is:
Let z = x + iy therefore Conjugate[z] = x - iy
x + iy - (x - iy) = 4
2iy = 4
iy = 2 ***multiply both sides by i
-y = 2i
y = -2i
Now from my understanding y is supposed to be a real number, is it not? So what exactly does
y = -2i represent? What region would it be in the complex plane?
And my attempt for 2:
|z| = 1 represents a circle of unit radius 1.
Given 1+z and |z|=1, I changed this to into the equation of a disk in the complex plane (can I even do that?)
Let z = x + iy
|z+1| < 1 ***For this step would I use less than, less than or equal to, or just equal to?
|x+iy+1| < 1
(x+1)2 + y2 < 12
Now this gives me an equation for a circle of radius 1 centred around the point (-1,0)
Is this correct?
Thanks
2iy = 4
-y = 2i
y = -2i
Let z = x + iy
|x+iy+1| < 1
(x+1)2 + y2 < 12
Is this correct?
Thanks
z-conjugate(z)=4 has no solutions in the complex plane, as you've correctly deduced. So there is no region. It's just the empty set. For the second part, if |z|=1 is a circle around z=0 of radius 1 then isn't |z-c|=1 a circle around z=c of radius 1? |(z+1)-1|=|z|=1.
I do not understand how z - conjugate(z)=4 has no solutions in the complex plane. Can you explain that?
You explained it. z-conjugate(z) is a purely imaginary number, it's 2yi where y is real. 4 is real and not zero. They can't be equal.
Okay that makes sense, thank you!
  • · Replies 17 ·
  • · Replies 27 ·
