Understanding Homogeneity & Isotropy in FRW Metric
binbagsss
So in deriving the metric, the space-time can be foliated by homogenous and isotropic spacelike slices.
And the metric must take the form:
##ds^{2}=-dt^{2}+a^{2}(t)\gamma_{ij}(u)du^{i}du^{j}##,
where ## \gamma_{ij} ## is the metric of a spacelike slice at a constant t
QUESTION:
So I've read that:
1) Homogenity would be broken if the a(t) was taken outside the metric
2) By isotropicity there can be no cross-terms dtdx, dtdy, dtdz.
What I know:
homogenous means the same throughout - translationally invariant.
isotropic means the same in every direction - rotationally invariant.
But I'm struggling to see how 1) and 2) follow from this. As stupid as it sounds, I don't really see where time comes in when these properties are only on the spacelike slices.
Cheers.
binbagsss said:
the metric must take the form...
No; "must" is incorrect. The correct statement is "one can always choose coordinates in which the metric takes the form..." See further comments below.
binbagsss said:
I've read
Reference please? A general note: statements like "I've read" or "I read somewhere" are red flags that you should be giving a specific reference, not a general vague statement. We can't tell whether what you've read is reliable if we can't read it ourselves.
What does "taken outside the metric" mean? Does it mean it multiplies the entire RHS, instead of just the spatial part? I'm going to assume it does in the rest of this post.
More precisely, the fact that the spacetime is isotropic means we can always choose coordinates in which there are no cross terms. See further comments below.
Yes.
Yes.
Is it both 1) and 2) that you don't understand, or just 1)? Your next statement seems to relate to 1), not 2).
The spacelike slices depend on the coordinates you choose. Statements 1) and 2) are really statements about how you can choose coordinates. I pointed that out above in my response to 2), about what "isotropic" means, but it goes for "homogeneous" too. "Homogeneous" does not mean you can't have ##a(t)## multiply the time part of the metric as well as the spatial part; it means that in a homogeneous spacetime, you can choose coordinates such that the time part of the metric is just ##- dt^2##, a constant, independent of the coordinates. If you choose other coordinates for a homogeneous spacetime, then the time part of the metric might have a function ##a(t)## multiplying it (or a function of any of the coordinates). That doesn't mean the spacetime isn't homogeneous; it means you chose coordinates differently.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
