Understanding Imm Files: Time Stamp Header and Accessing Information
  • Thread starter Thread starter nuwan78
    files
IMM files are image files often used in specific applications like X-ray scattering analysis and are typically associated with CCD cameras. Each IMM file may be preceded by a 1024 kB time stamp header, which contains metadata about the image, although this can vary by application. The header file's location and access methods depend on the specific camera and its software; contacting the manufacturer is recommended for detailed specifications. Understanding the file format is crucial for effective image processing and analysis. Proper access to these files can enhance data interpretation and results.
nuwan78
Hi Guys!,
I have heard that imm files are image files and that each such file is preceded by a time stamp header file of 1024 kB (kilobytes), is this always the case?
Also what is this time stamp ( or just header) file ? What information does it include about the corresponding image file and where exactly is this header file situated and how to access it.
So many questions! But really appreciate if someone can answer them all.
Thanking in advance
Pingona
nuwan78 said:
Hi Guys!,
Thanking in advance
Pingona
What is the context of your question? What is the application? What are these files used for?
Nuwan. File extensions (or files types) are operating system dependant and not necessarily unique. In windows the most common association of ".imm" files is the email client "incredimail".
The application is image processing. We use the images ( in *.imm format) from a CCD camera and analyze them to reproduced results that are related to X ray scattering.
In the case of a lesser-known file format such as this, I'd contact the camera manufacturer and see if they can provide a file format specification that yells you what is contained. If they won't then they usually at least provide a utility that can extract or allow you to read the pertinent information.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
