Understanding the Relationship Between Power Input and Torque in Wind Turbines
  • Context: Undergrad
  • Thread starter Thread starter boyle007
    Input Power Torque
The discussion centers on the relationship between power input, torque, and rotational speed (rpm) in wind turbines. Participants explore the equations governing these relationships and the implications for power generation, including the dynamics of torque and rpm in practical applications.
  • One participant presents an equation relating power, torque, and rpm, suggesting that a certain applied torque leads to a specific rpm and power output.
  • Another participant challenges this interpretation, noting that applied torque generally creates acceleration rather than a steady rpm, and that real-world systems may not exhibit a linear relationship between torque and power output.
  • A different participant emphasizes that many turbines operate at a constant rpm, where the net torque on the rotor is zero, indicating that the torque from the blades matches the generator/load torque.
  • There is a discussion about the chain of causality, with one participant questioning whether the sequence of wind (or water) causing torque, leading to rotation and then power generation, is accurate.
  • Another participant clarifies that rotation does not guarantee power generation if there is no load connected to the generator.
  • Participants discuss the possibility of extrapolating power input from known values of applied torque, rotation speed, and power generated, with one suggesting that input power can be calculated from transmitted torque and angular velocity.
Participants express differing views on the relationship between applied torque, rpm, and power output, with no consensus reached on the interpretation of these dynamics. Some agree on the basic sequence of causality, while others highlight complexities that challenge this view.
Participants note that the relationship between torque and rpm may depend on specific turbine designs and operational conditions, and that the dynamics of power generation can vary significantly between different types of turbines.
boyle007
Hello Physics Forum,
Thanks to the Physics Forum, I learned an equation that helps me understand the relation between torque and power generated for a wind turbine. The equation is
P = m * ω
and can be rewritten as
m = P/n * 30/∏
where m = applied torque, P = power generated, n = rpm, and ω is a constant * rpm
I understand the above equation, however, I would like to know the following:
If the applied torque is of a certain amount, it will produce an rpm of a certain amount, which will in turn generate a power of a certain amount.
Is that a correct interpretation?
I'll take a specific example to help me understand better. Suppose we put the following numbers into the above equation and get:
12,738 Nm = 2,000,000/1,500 * 30/3.14
If the power input produces 12,738 Nm of applied torque, then that will produce an rpm of 1,500, and that in turn will produce 2,000,000 MW of power generated. So, regardless of the source of the power input (e.g. wind or water power), so long as it produces enough power to generate 12,738 Nm of applied torque, then the power generated will be 2,000,000 MW.
The key, I am thinking, is to produce enough applied torque to generate the required rpm and therefore generate the power output. Is that a correct interpretation?
Thank you
I don't know the specifics of your setup, but in general an applied torque creates an acceleration, not a steady RPM (ignoring non-conservative forces). This may be a custom solution for your particular system.
In the real world an applied torque will accelerate the system until the
drag torque + generator torque = applied torque
Depending on the design of your generator, generator torque and RPM may not be directly related. This may cause power output to not be linear with RPM.
Otherwise, yes a certain applied torque means a certain RPM which means a certain power output.
however - I think in the real world wind generators and such are run at a constant RPM, and the power output is varied to maintain RPM. This way, in high winds they produce a lot of power but turn at the same RPM. (That's just my guess though)
In general no.
It's interesting to compare the equations for linear motion with rotation. You will be familiar with Newton's
F=m*a
where F= Force, m=mass and a = acceleration
The corresponding equation for rotation is
T= I * a
where T = Torque, I = Moment of inertia, a = angular acceleration
As elegysix said, many turbines run at a constant rpm. Under those conditions the net torque on the rotor is zero. The torque generated by the blades exactly matches that of the generator/load. If the net torque is zero then the angular acceleration is zero and that corresponds to a constant rpm. If there was a net torque the rotor would accelerate.
Don't confuse net torque with the torque in the shaft. The net torque might be zero but that doesn't mean the shaft isn't transmitting a lot of torque from one end to the other.
Thanks for the answers.
I am still a bit confused. I would like to know the general before the details; first the chain of causality: the prime force (wind, water) begets torque on the shaft, which begets rotation, which begets power generation. Is that a correct "chain" of causality?
If I understand elegysix correctly, then in general and ignoring the details for a moment, "a certain applied torque means a certain RPM which means a certain power output."
Secondly, if I know the numbers shown above (applied torque, rotation speed, power being generated); can one extrapolate the amount of "power input", i.e. the amount of force needed to produce the applied torque, rotation speed, and power generated? I know the power input has to be at least slightly greater than the power generated. Also, how is that "power input" measured? I know power generated is measured in watts.
Thanks once again
That's the basic sequence but rotation does not automatically imply power generation. There might be nothing connected to the generator.
Perhaps look at it this way..
A turbine starts from rest with no load connected to the generator.
The wind blows causing a net torque
Tnet = Trotor-Tgenerator
However since Tgenerator=0 (no load yet) that means Tnet >0 and the rotor accelerates up to it's design speed.
If a load is not applied at this point it might keep accelerating to destruction.
So a load is normally applied and the power extracted is sent to the grid.
The load is constantly adjusted to keep the rpm within design limits despite varying wind speeds. This results in varying power output.
If it's operating at constant rpm the net torque is zero. (Trotor-Tgenerator=0)
No. In general a net Torque causes a certain acceleration not a certain rpm. It's the details of the turbine design that cause it to target constant rpm not the basic physics.
Crude turbines such as those used to pump water from a well tend to work differently to those designed to generate electricity. Crude water pumping turbines tend not to be designed constant rpm. If the wind blows they accelerate and pump water faster. To stop them spinning too fast some types employ flexible blades to shed (waste) wind.
If you can measure the torque transmitted through the shaft and the rpm then yes you can calculate the available input power.
Input Power = transmitted torque * angular velocity
Angular velocity can be calculated from the rpm.
To calculate the output power you need to know the efficiency of the generator.
  • · Replies 41 ·
  • · Replies 69 ·
18K
  • · Replies 72 ·
11K
