Understanding Waves: Questions on Phase Differences and Interference Patterns
  • Thread starter Thread starter WesleyHuang
    Waves
WesleyHuang
Sources A and B emit long-range radio waves of wavelength 320 m, with the phase of the emission from A ahead of that from source B by 90°. The distance rA from A to a detector is greater than the corresponding distance rB from B by 82 m. What is the magnitude of the phase difference at the detector?
2.
In a double-slit experiment the distance between slits is 5.2 mm and the slits are 0.82 m from the screen. Two interference patterns can be seen on the screen: one due to light of wavelength 450 nm, and the other due to light of wavelength 580 nm. What is the separation in meters on the screen between the m = 4 bright fringes of the two interference patterns?
The first one is actually an online-test question. I have tried 3 times using the method from the textbook, but i still haven't got the right answer. Can anyone help me? THANKS!
You understand, don't you, that you have to show what you have done yourself?
Hello! What i have done for the first question is:
devide the wave length 320m by 4, since A is 90° ahead (a quarter of a cycle)
then I take 82m away from it, since the wave from source A goes 82m further
finally i just take the ratio of the phase difference with the wavelength and multiply the result by 2π in order to convert the unit to radian.
is it correct?
i can't do the second one. i thought the 2 lights will not have any bright fringes, because the wavelengths are different, double-slit interference will not occur...
do you think so?
Tips:
1. How much is A in front of B? (90 deg)
How big is the phase difference between A and B just because wave A has to travel longer?
2. For both 450 nm and 580 nm a double-slit interference will occur. What distance for m=4 at 450 nm and what distance for the 580 nm wave?
I've got the answers now! thanks!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
