Uniform Circular Motion of a motorcycle
The discussion focuses on calculating the centripetal force and normal force acting on a motorcycle traveling at a constant speed of 25.0 m/s over a hill with a radius of curvature of 126 m. The mass of the motorcycle and driver is 342 kg. The calculated centripetal force is 1.70 x 103 N, which is confirmed as correct. However, the normal force was initially miscalculated as 5048 N, while the correct value is 1.66 x 103 N, derived from the equation Fn = Fg - Fc, where Fg is the weight of the motorcycle.
  • Understanding of centripetal force calculations using the formula F(centripetal) = mv2/r
  • Knowledge of gravitational force calculations, specifically Weight = mg
  • Familiarity with the concepts of normal force and its relationship to other forces
  • Basic physics principles related to uniform circular motion
  • Study the derivation and application of the centripetal force formula in various scenarios
  • Learn about the effects of radius of curvature on forces in circular motion
  • Explore the relationship between normal force and gravitational force in different contexts
  • Investigate real-world applications of uniform circular motion in vehicles and other objects
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for examples of force calculations in practical scenarios.
ShamTheCandle
A motorcycle has a constant speed of 25.0 m/s as it passes over the top of a hill whose radius of curvature is 126 m. The mass of the motorcycle and driver is 342 kg. Find the magnitude of (a) the centripetal force and (b) the normal force that acts on the cycle.
F(centripetal) = mv^2/r
Weight=mg
Using the formula for centripetal force, I found that the answer for part (a) is 1.70 x 10^3 N. My answer matches with the back of book. So it is right. However, for part (b) I used that
Normal Force = Weight + Centripetal Force = 5048 N. I don't think it is right since the back of the book says the answer is 1.66 x 10^3.
Thank you for helping.
thefifthlord said:
Centripetal force always acts towards the center, in this case the center is up, so its actually
Edit: Sorry typo.
Fn = Fg - Fc
To anyone who is reading this thread, i need major help here: https://www.physicsforums.com/showthread.php?t=356807
Ohhh, I see. This makes sense now. Thank you!
12K
  • · Replies 28 ·
