Understanding Uniform Circular Motion: Explained and Tested | Stephen
In uniform circular motion, while the speed remains constant, the velocity is not constant due to the continuous change in direction. Velocity is a vector quantity, meaning it includes both speed and direction; thus, any change in direction constitutes a change in velocity. Although angular velocity can be constant, the presence of centripetal acceleration indicates that the overall velocity is not constant. The distinction between speed (a scalar) and velocity (a vector) is crucial in understanding motion in a circular path. Therefore, in uniform circular motion, the speed may be constant, but the velocity is not.
StephenDoty
I had a test today, there was a question about uniform circular motion. Isn't the velocity constant since the speed is constant? I know angular velocity is constant, but the question's answers only state constant speed or velocity.
Thank you.
Stephen
Velocity is a vector. Speed is a scalar (the magnitude of the velocity). If the direction of motion changes, the velocity changes, even if the speed is constant.
Yes the velocity is constant since the speed is constant, but only for tangential speed, you are forgetting the centripetal component of circular motion. As phlogistonian stated velocity is a vector i.e... speed and direction, a change in both or either will cause an acceleration.
