Uniform distribution of a disc
The discussion revolves around finding the marginal probability density functions (pdf) for a uniform distribution over a disc of radius 1. The joint pdf is established as 1/π for points within the disc defined by x² + y² ≤ 1. To derive the marginal pdf of x, one must integrate the joint pdf over the appropriate limits for y. The correct limits for integration are determined to be from -√(1 - x²) to √(1 - x²), reflecting the possible y-values for a fixed x within the unit circle. The conversation emphasizes the importance of visualizing the unit circle to accurately set the integration boundaries.
mathmathmad
Consider a disc of radius 1 in the plane D in R
D = {(x,y) in R | x^2+y^2 <= 1}
write the marginal pdf of x and y
so the joint pdf is 1/Pi for x^2 + y^2 <= 1 <- correct?
but how to I get the marginal pdfs?
You have
<br /> f(x,y) = \frac 1 \pi<br />
as the joint density. As in every case the marginal density of one variable is found by integrating out the other. Suppose you want the marginal density of x - you need to integrate out y.
<br /> g(x) = \int_a^b \frac 1 \pi \, dy<br />
The question is: what should you use for the limits a and b?
Draw the unit circle and see the set of y-values that are possible when x is fixed.
a=0
b=sqrt (1 - x^2) ?
mathmathmad said:
a=0
b=sqrt (1 - x^2) ?
Try again. Did you draw the picture?
a = - sqrt (1 - x^2)
b = sqrt (1 - x^2)
or should it be -1 to 1
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
