How to Achieve Uniform Distribution of Points on a Sphere?
To achieve a uniform distribution of points on a sphere, the correct parametrization involves using spherical coordinates with specific transformations for theta and phi. The formulas theta = πR1 and phi = arccos(1 - 2R2, where R1 and R2 are uniformly distributed random numbers between 0 and 1, ensure that the area element is constant. The alternative approach proposed, theta = πR1 sin(R1) and phi = 2πR2, does not maintain the necessary uniformity across the sphere's surface. To derive the correct solution, one must find the joint density of theta and phi and integrate to obtain marginal and conditional densities. This method confirms the validity of the original formulas for achieving uniform distribution on a sphere.
kaksmet
Hello
I am trying to make a uniform distribution of points on a sphere. I can find the answer
\theta=\pi R_1
\phi = arccos(1-2R_2)
where R1 and R2 are uniformly distributed random numbers between 0 and 1.
To me, it feels like
\theta=\pi R_1 sin(R1)
\phi = 2\pi R_2
should also give the correct distribution. Is that the case, and if not how can I understand why not this but the above solution is true? How can I calculate my way to the first answer?
thanks!
Tomas
Well, you want a parametrization x(u,v) : (0,1) x (0,1) -> the unit sphere S2
such that the unit of area
|x_u \times x_v|
is constant, where \times is the cross product.
It should be simple to verify that this works for the solution given but does not work for your solution. To be more specific, in the solution given,
x(R1,R2) = s(pi R1, arccos(1-2R2))
where s is the function for spherical coordinates, i.e. s(theta, phi) = (sin theta cos phi, sin theta sin phi, cos theta)
To write theta and phi in terms of uniforms you first need to find their joint density. Since the points are uniformly distributed over the area, the probability of the rectangle [theta,theta+dt] x [phi,phi+dp] is the proportional to the area on the sphere which is
the magnitude of the cross product [dx/dtheta] x [dx/dphi] *(dt*dp).
From this by normalizing you get the joint density f(theta,phi) and integrate to get a marginal density e.g. f(theta) and a conditional density f(phi|theta). The cumulative distribution of any random variable is uniformly distributed, so theta=F^{-1}(R1) and phi=F^{-1}(R2|theta)=F^{-1}(R2|F^{-1}(R1)).
Hope this helps - what answer do you get from this process?
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
