A_lilah
- 52
At x = 1.00 m, the voltage is 4.00 V. At x = 3.00 m, the voltage is also 4.00 V. Assuming that there is a steady, uniform non-zero electric field over this entire region, give four possible directions of that electric field.
E = (delta V)/d
Ue = qV
(the electric potential = charge * voltage)
I'm not entirely sure, these are just the ones that sort of relate the electric field with voltage.
For these charges to have an equal voltage in the electric field, the force of the electric field * the distance between either charge and one of the plates should = 0 (from the first equation above), so anywhere in the field where they are at the same y coordinate (in line with each other), they should have the same voltage. This gives me two directions for the field- it can point up or down (switching the positive and negative plates) and the voltages could be the same:
____________ <-- negative plate
^ ^ ^ ^ <---direction 1
--(1m)----(3m)------------------->x axis
____________ <-- positive plate
and if you switch the negative and positive plates, the field points down, my second direction, but I don't see how you could have two additional directions, so perhaps I am thinking about this wrong. Any insight would be great! thanks
