Can an Uninterruptible Power Supply Prevent Voltage Spikes from a Refrigerator?
A small refrigerator is causing voltage spikes that disrupt a projector's image when the compressor turns off. The user is considering an uninterruptible power supply (UPS) for protection but is uncertain if it can react quickly enough to prevent the issue. Suggestions include using a surge protector for the refrigerator and checking the wiring of outlets to ensure they are correctly configured. An isolation transformer is also mentioned as a potential solution, though it may not guarantee results. The discussion emphasizes the importance of addressing the source of the electrical noise and exploring simple fixes first.
Downsidesunny
I have a small refrigerator in my projector room. Many times when the compressor in the refrigerator turns off it sends a voltage spike through my home circuitry and distorts the projection image.
Example: When I'm watching a movie on the projector everything is working correctly. Then the refrigerator compressor turns off and the movie screen goes out and I can only see white noise on the projection screen.
I would like to know if an uninterruptible power supply would correct this issue. I know they work for power outages, however I'm not sure if they will protect over voltages with a reaction time fast enough to correct this problem. I currently have the projector plugged into a simple surge protector and this obviously does not help. Thank You for taking the time to read this and any help is appreciated.
Have you tried using a surge protector for the refrigerator also? That should limit the amount of spike energy going into your house wiring. If you're in the US then it might help if you put your projector and refrigeration on opposite legs of your house wiring (if possible).
I don't know about the UPS. I don't think it would give you any more protection than a surge protector when on AC power.
Yes, I forgot to mention that I am in the U.S. and that it is not possible for me to put the refrigerator on a different breaker in the house without running an extension cord into another room. I was trying to avoid that by getting a UPS. The refrigerator is currently plugged into a surge protector however. Thanks for the reply.
These problems can be difficult to remedy. It's normal for inductive loads to spike the power line when they switch off. I once had a programmable thermostat (which was connected to the ac mains for power) that would randomly lock up when the heatpump switched off. After being unsuccessful at fixing it myself I called the manufacturer and found out that it was a design oversight. They replaced my thermostat with a new redesigned unit at no cost to me.
The only other thing I can think of that might help you is an isolation transformer. These are probably in the same price range as the UPS that you were considering. But of course there's no guarantee that it will work.
When I've worked on solving any kind of noise problem in the past; go to source of the noise. Just sayin'
I'd start with real simple stuff first.
This little $5 tester should be in every homeowner's tool drawer.
http://www.walmart.com/ip/GE-3-Prong-Receptacle-Tester/16561511
First thing to check is - are the outlets wired right?
I have an incandescent touch lamp that acted erratic. Turning on any CCF bulb on the same outlet turned the touch lamp off.
Found the outlet wired wrong: hot & neutral swapped and Earth ground not connected.
Surprising it happens on the transition to OFF. That sounds more like arcing in the thermostat than an inductive voltage spike.
Does it happen every time, or intermittently ?
Does it happen when you simply unplug the fridge while running?
Next - do the fridge and projector perhaps share an extension cord ? Separate them if you can.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
