Unit Conversion W➝J: Break-Even in 50 Years?
The discussion centers on calculating the break-even point for a power plant with an effective power generation of 5.43 x 10^7 W and an energy requirement of 9 x 10^16 J. Participants confirm that the break-even time is indeed around 50 years, despite a minor typo in the power value used for calculations. One contributor notes issues with Wolfram Alpha's output, suggesting it may require additional input to clarify results. A strong conclusion is drawn that investing in this power station may not be worthwhile, although some participants question the criteria for this conclusion. Overall, the conversation highlights concerns about the viability of the power plant based on the break-even analysis.
JJ91
Effective Power generation of the plant is 5.43*10^{7}W but it will required 9*10^{16}J to be created.
Essentially the break-even will after solving equation Energy required/Power Generated however I get results of almost 50 years. Would this be correct?
https://www.wolframalpha.com/input/?i=9E16+Joules+/+5.34E7+Watts
In your problem statement you say the Effective Power is 5.43 x 107 W, but on the web page calculation you used 5.34 x 107 W. A typo no doubt. But yes, the result can be expected to be in the neighborhood of 50 years.
Sans the typo gneill noted, this is correct.
Your link stops for me at 1.685×109 J/W. (Perhaps I've overused wolfram alpha?) Sometimes it helps have to cajole wolfram alpha to that it will take the answer a step further.
https://www.wolframalpha.com/input/?i=convert+9E16+Joules+/+5.34E7+Watts+to+years
The conclusion is simple. There is no point to invest a broken penny into this power station.
:confused: Huh? Did you fail to properly state the problem? What is the criterion for your conclusion?
I don't like the title of that thread. That problem has nothing to do with unit conversion.
