Unit Conversions: Calculate Time for a Snail to Travel 1.00km at 5.25cm/min
  • Thread starter Thread starter lettertwelve
    Unit
To calculate the time for a snail traveling at 5.25 cm/min to cover 1.00 km, the correct approach involves using the formula for time, t = d/r. The initial calculation mistakenly suggested a time of 0.00315 hours, which is incorrect. Proper dimensional analysis shows that the snail would take approximately 317 hours, or about 13.23 days, to travel that distance. The discussion emphasizes the importance of checking unit conversions and ensuring that results are reasonable. Ultimately, a systematic approach to conversions yields a more accurate understanding of the snail's travel time.
lettertwelve
A snail travels on average 5.25 cm/minute. How many hours would it take to travel a distance of 1.00km?
none
5.25cm/min X 60min/hr X 1m/100cm X 1km/1000m
cm, min, and m cancel out and the answer ends up to be .00315
correct??
correct
tater08 said:
correct
are you more than 100% sure :P
do you have time to check 2 more for me??
your reasoning is correct as well and I am more than 100 percent certain
what about this one:
solid copper has a density of 8.92 g/mL. How many cm^3 does 0.75 lbs occupy?
i did: 8.92g/mL X 1000mL/cm^3 X 1lb/453.59237g
i'm missing something i believe, but i don't know what, and how accurate is my lb/g part, as well as where do i put the 0.75lb? if you could turn me in the right direction..
After you cancel out your units what are you left with? That would suggest what you need to do to get an answer in the desired form.
i believe i should only be left with lbs, but then i can't begin to figure out how i'd get rid of the cm^3
none
correct??
Hold on here. What are the units of 0.00315? If it's hrs, then that is one fast snail.
In the question, one is given speed and distance, and there is a relevant equation that gives time (duration) in terms of distance and speed (assume constant speed).
However in the solution given, one has multiplied speed by ratios of time and distance, and so the units would be for speed, which cannot be correct.
Please write an expression for time in terms of distance and speed, and then apply the appropriate ratios.
You were developing the units of a constant for converting. What is the statement of that constant after you do all that and cancel out your units?
The question is asking you how many cm3 is in .75 lb.
Use your new constant to convert it then at that point.
Wouldn't you start the equation with the 1.00km instead of the 5.25cm/min and use that as a conversion factor.
So it would be something like this:
?hrs=1.00km(10^3m/1km)(1cm/10^-2m)(5.25cm/1min)(60min/1hr)
Which would equal 31500000 and since you have to use sig figs it would be 3.15 x 10^7 hr
Correct me if I'm wrong.
none
correct??
No.
CS
Start off using the simple relationship d = rt, then solve for t.
t = d/r
Then it is just a matter of dimensional analysis.
CS
It won't live long enough.
Think about what the numbers mean.
5.25 cm/min is what in 1 hr? 60 times that? making it 315 cm in an hour?
That's what 3.15 m/hr?
Now if I have to go 1000 of those how fast can Slugo do it?
Won't that be 1000m/3.15 m/hr? Doesn't that yield hours?
2 weeks? He might make it back home in time to see the wife in her new shell.
317 hours, so 13.23 days.
Like LowlyPion wrote... 5.25cm/min >> 315 cm/hour >> 3.15m/hour >> 0.31746 hr/m *(1000m) >> 317.46 hrs
I think my point was to look at the conversions in steps to insure that each step meets a reasonableness test. If you are taking reasonable steps along the way, then maybe you will reach a reasonable result?
107 hours was simply not a reasonable answer.
That should have triggered your suspicions.
(How many years is 107 hours you think? We should all live so long?)
