How Do You Determine the Unit Digit of a^b?
  • Thread starter Thread starter PrudensOptimus
    Unit
To determine the unit digit of a^b, one can analyze the unit digits of powers of a fixed base a while varying b. This approach reveals patterns in the unit digits that repeat periodically. For example, the unit digits of powers of 2 show a cycle: 2, 4, 8, 6. By identifying the cycle length and using the exponent b modulo this length, the corresponding unit digit can be determined. This method provides a systematic way to find the unit digit for any positive integers a and b.
PrudensOptimus
Hi, is there any way to find Unit Digit of a expression, say
a^b
where a, b, are positive integers?
Mathematics news on Phys.org
Yes.
Hint: fix a, vary b, and ignore the irrelevant details, see if you can find a clue...
U mean a pattern?
Like 2^2 = 4, like 2^2222 = 4? Because 2222 is divisible by 2?
I mean something a little more rigorous. :smile:
Consider the values of 2^1, 2^2, 2^3, ...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
