What Is the Unit Vector of f(x) at (3,9)?
To find the unit vector parallel to the graph of f(x) at the point (3,9), the calculations yield a vector of (1/sqrt(37))<6,-1>. The discussion clarifies that the normal vector can be either (1/sqrt(37))<-1,6> or (1/sqrt(37))<1,-6>, indicating that both directions are valid. The confusion about the signs arises from the understanding that the ± symbol refers to the direction of the vector rather than the signs of its components. The correct normal vector is derived from the relationship between the coordinates, specifically as <-y,x> or <y,-x>. The participants seek clarity on the derivation of the normal vector and its properties.
haxtor21
Find a unit vector (a) parallel to and (b) normal to the graph of f(x) at the given point. Then sketch a graph of the vectors and the functions.
Function:
f(x)=xx
Point:
(3,9)
http://img543.imageshack.us/img543/6964/gedc0203.th.jpg
Uploaded with ImageShack.us
<cos(x),sin(x)> is always a unit vector.
For the normal vector, just find a vector orthogonal to the one you have. Both <-x,y> and <x,-y> are orthogonal to <x,y>, or if you want to cheat, use <0,0,1>.
Function:
f(x)=xx
Point:
(3,9)
Your vector, \vec{v}\,, is a unit vector.
\left\|\vec{v}\right\|=\sqrt{\cos^2(\,\arctan(6))+\sin^2(\arctan(6))\,\,}=\sqrt{1}=1
BTW,
\sin(\arctan(6)) =\frac{6}{\sqrt{1+6^2\,}}=\frac{6}{\sqrt{37}}
and
\cos(\arctan(6)) =\frac{1}{\sqrt{1+6^2\,}}=\frac{1}{\sqrt{37}}
Ok, so far I have a) done. How exactly am I supposed to do this? The back of the book says the answer is +-(1/sqrt(37))<6,-1>. Where does the +- come from and how did they get that answer (looks iverse. According to what you said, I would just stick a negative in either component (?) ).
Correct. The +- means that either answer is acceptable, though to be thorough you can have both answers.
So you are saying that I can have (1/sqrt(37))<-1,6> or (1/sqrt(37))<1,-6> for b) even though the book says the answer is (1/sqrt(37))<6,-1>?
So then I would guess the +- reffers to the direction of the vector compared to what it was previously, but it has no relationship with the signs inside the < , > components correct?
I'm sorry, I was wrong. The normal vector of <x,y> is <-y,x> or <y,-x>.
How do you know that is the normal vector? is there a proof sort of thing somewhere?
