Universe Without Higgs: What Would it Look Like?
In summary, the universe with standard model w/o Higgs would look very different than the one we have today. The most stable particles would be the pions, nucleons, and alpha particles, and there would be very little light matter. The weak force would be a long-range force and there would be new long-range forces mediated by the massless pions and SU(2) gauge bosons.
tom.stoer
172
How would the universe with standard model w/o Higgs look like?
I guess confinement would still cause hadronization. Due to zero rest mass pions would be stable. Nucleons as lightest baryons would be stable b/c there is not lighter state into which they could decay (even so the weak force is now a long-range force). The typical fusion processes of light nuclei would produce at least alpha particles.
Therefore there would be a dilute gas of massless pions, nucleons, some alpha particles, massless leptons and photons as well as massless W- and Z-bosons.
Am I correct?
Just thinking about pions to start things off, surely charged ones would osscilate freely into (eg) muon and neutrino pairs, with some sort of equilibrium being reached. Neutral ones could still transmute into pairs of photons, but could equally easily be formed from photon collisions.
So wouldn't it actually be more like a plasma or "soup" than a gas?
My idea is the following:
The pion-lepton decay vanishes in the chiral limit; the pion-photon decay may still be non-zero due to the axial anomaly, therefore neutral pions would indeed oscillate into photon pairs.
But we do not have two but six flavors and therefore only the U(6) singulet state (= the eta-prime with other quark contributions c, b, t) would oscillate into photon pairs; the pion - or whatever it may be with quark mixing of c, b, t - would have vanishing el.-mag. decay constant and would be stable; therefore all U(6) states but the singulet are stable with zero coupling constant.
Are there any interesting consequences of the fact that SU(2)xU(1) is unbroken? I think that there are enough fermions around that the SU(2) is not confining. But there should be a new long-range force mediated by the massless SU(2) gauge bosons, yes? What does a long-range nonabelian gauge field look like?
In addition we have the unbroken U(1) hypercharge which I guess looks like electromagnetism with different charges and a different coupling strength.
The parity-violating "weak" force is no longer weak or short-ranged, so presumably parity violation becomes a lot more obvious?
Do the massless pions effectively mediate another new long-range force?
It seems like the U(6) equivalents of the nucleons are the only stable massive particles around. Are there atom-like bound states of multiple nuclei, held together by one or more of the new long-range forces?
Wouldn't the U(6) singlet be massive because of the anomaly, and thus simply decay into U(1) gauge bosons?
Interesting ideas!
This is something I forgot! The beta-function for QCD with 6 flavors reads
[tex]\beta(g) = -\left(\frac{11}{3}N_C - \frac{2}{3}N_f\right)\frac{g^3}{16\pi^2} = -\left(11 - 4\right)\frac{g^3}{16\pi^2} \lt 0 [/tex]
I do not know how to count the chiral fermions for the SU(2), including both leptons and quarks, so I can't say whether this SU(2) is confining or not. If yes, the 'SU(2) hadrons' would have to be SU(2) singulets just like SU(3) hadrons. Then all what I said above was nonsense and the world would look totally different.
I don't know how a non-confining i.e. long-range non-abelian gauge theory would look like, but certainly very different from what we know and again all what I said above was nonsense.
Yes, something like that; the other mesons remain massless Goldstone bosons.
Confinement seems like an important issue to me, and I don't think there are enough massless fermions to keep the SU(2) deconfined. For example, SU(3) confinement should still render all the fermions carrying weak charge due to quarks massive. That just leaves 3 generations of chirally coupled doublets.
If the SU(2) did go to weak coupling in the IR, then similar to N=4 SYM, I would think that an IR free gauge theory would still have something like the coulomb law (perhaps with a minor logarithmic modification). There would of course also be lots of non-abelian radiation.
Assuming confinement, neutrinos, etc. would no longer be around, but probably there are composite fields with quantum numbers similar to the fields we observe. I guess electromagnetism would now be pure hypercharge?
Right - the proton would be a little lighter, but it would still be there.
Part 1: Bosons
There wouldn't be a pion.
You're right that the pion becomes a true massless Goldstone boson. But then it gets "eaten" to become the longitudinal component of the W and Z by something we call "the Higgs mechanism". So the W and Z gain a mass, to the tune of 20-30 MeV. Interestingly, the lifetime of these particles becomes close to that of the charged pions.
which field would cause this Higgs mechanism?
Part 2: Nuclei
I'm not 100% sure what happens to nuclei. The N-N force still has a repulsive core, but the attractive piece is now mediated by the W and Z. These are vectors, so that means that the p-p and n-n forces are repulsive, and only p-n is attractive. The range of this force is longer, but the strength - the coupling - is less. I suspect you still have nuclei, but they are larger, more weakly bound, and probably more prone to alpha-decay.
Part 3: Leptons
The electron gains a mass from QCD at loop level. It's very small - maybe meV or less. So atoms are very large: microns, possibly millimeters. The muon and tau gain mass through the same mechanism, so have the same mass. So flavor becomes a quantum number much like color today. We wouldn't perceive them as distinct particles, but our atomic shells could hold 3 times as many electrons: carbon would be a noble gas.
I think the point is that the chiral condensate [itex] \langle q \bar{q} \rangle [/itex] carries SU(2) charge and hence leads to another Higgs another effect.
Is it possible that the weak force reaches strong coupling before the scale of chiral symmetry breaking, so that we should think in the opposite order?
I believe it's a quark bilinear term - you get a vev of order Lambda_QCD. But the key is that the pion has the same quantum numbers as the longitudinal piece of the W, so once it becomes a Goldstone, it's eaten. Actually, it's eaten today, and contributes a tiny piece to the W mass, but since the Higgs vev is so much larger, we don't care about it.
This is how Technicolor works. You add pions with ~4000x the mass to the theory, and now the W gets a mass from them comparable to the observed mass.
If we have six flavors of massless quarks, aren't there 6^2 - 1 = 35 pions? Then if 3 get eaten we should still have 32 massless pions.
Can you explain how this works?
That's a good point - there would be 30 nucleons, 15 charged and 15 neutral. (I'm assuming N-type is lighter than Lambda-type)
Regarding the beta-function and confinement for an unbroken SU(2): the weak isospin would replace the color, i.e. NC=3 → 2. But how do you count the 'flavors'? The flavor in QCD are 'identical copies' of quarks which are not distinguished by the color-gauge interaction. Now what about weak force? what are these new flavours? how do you count them? You have again 3 generations i.e. 6 flavors (u,d,s,c,b,t), I guess you have another 6 leptonic flavors (electron, electron-neutrino, ...), but what about an additional factor of three for the quarks? the weak SU(2) does not distinguish between different colors. So do we have 6+6 = 12? Or do we have 3*6+6 = 24?
The_Duck said:
If we have six flavors of massless quarks, aren't there 6^2 - 1 = 35 pions? Then if 3 get eaten we should still have 32 massless pions...
But [itex]c\bar{s}[/itex] and [itex]t\bar{b}[/itex] have the same quantum numbers as [itex]u\bar{d}[/itex], so wouldn't they get eaten by the [itex]W^+[/itex] too?
Could the latter swallow all of these together, or would some form of "quantum indigestion" occur? :)
1. What is the Higgs field and why is it important?
The Higgs field is a theoretical concept in particle physics that is responsible for giving particles their mass. It is important because without it, particles would not have mass and the universe as we know it would not exist.
2. How would a universe without the Higgs field be different?
In a universe without the Higgs field, particles would not have mass and therefore, they would not be able to form atoms. This means that there would be no matter, no stars, and no galaxies. The universe would be a vast and empty void.
3. Would the laws of physics still apply in a universe without the Higgs field?
Yes, the laws of physics would still apply in a universe without the Higgs field. However, these laws would be vastly different as the fundamental building blocks of matter would be different without the Higgs field.
4. How would life be possible in a universe without the Higgs field?
Life as we know it would not be possible without the Higgs field. The stability of atoms and the formation of complex molecules, which are essential for life, would not be possible without the Higgs field giving particles their mass.
5. Is it possible for a universe to exist without the Higgs field?
It is possible for a hypothetical universe to exist without the Higgs field, but it is highly unlikely. The Higgs field is a fundamental part of the Standard Model of particle physics and its existence has been confirmed by experiments at the Large Hadron Collider. It is an integral part of our current understanding of the universe.
  • Beyond the Standard Models
