B Upside down buoyancy (Have you seen this?)
  • B
  • Thread starter Thread starter kuruman
    Buoyancy
The discussion highlights the intriguing concept of upside-down buoyancy, emphasizing its cleverness and novelty. It notes that the floating equilibrium on the bottom surface is inherently unstable when considering static potential energy. Stability is instead derived from dynamic oscillation effects, which require extensive explanation in supplementary materials. The accompanying article provides in-depth analysis and figures to support these findings. This phenomenon challenges conventional understandings of buoyancy and stability in fluid dynamics.
kuruman
Education Advisor
Insights Author
Devilishly clever.
  • Love
Likes Arjan82, DaveE, Leo Liu and 8 others
Cool. I had definitely never heard of that before.
Likes etotheipi, A.T. and vanhees71
Motore said:
Here is the accompanying article:
https://arxiv.org/abs/2003.04777
So the floating equilibrium on the bottom surface is actually unstable based on static potential energy alone (Fig 3B). The stability comes from dynamic effects of the oscillation, which take like 5 pages of supplementary text to explain.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
