Upstream effect on fluid thread
  • Thread starter Thread starter Keith_McClary
    Fluid Thread
Adjusting a tap to create a 2 mm water thread results in droplet formation 10 cm below the spout, with observed ripples both above and below a hair touching the thread. The phenomenon raises questions about the dynamics of liquid threads, particularly the presence of upstream ripples. Research indicates that the group velocity of capillary-gravity waves allows for energy transport both upstream and downstream. The complexities of these interactions challenge simple explanations. Understanding these dynamics requires delving into advanced fluid mechanics principles.
Keith_McClary
I adjust my tap to produce a thread of water about 2 mm in diameter. It breaks up into droplets about 10 cm below the spout. I touch the thread near the spout with the tip of a single hair (from my head). I see ripples (standing, not travelling) on the thread 1-2 cm below the hair. The strange thing is, there are also ripples 1-2 cm ABOVE the hair.
I Googled up
Break-up dynamics of fluctuating liquid threads.
Just reading the abstract tells me that this is not simple.
Can the upstream ripples be explained on general principles without getting into these complications?
(This was inspired by a question by 23scurtu on http://.com/questions/200815/why-does-a-continuous-water-stream-form-ripples-when-colliding-with-a-surface/200943#200943 with videos of the effect. )
The group velocity of capillary-gravity waves exceed the phase velocity, so energy is transported 'upstream' as well as downstream.
http://math.mit.edu/classes/18.376/TermPapers/18376_Term_Paper_Fan.pdf
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
