How High Will Each Ball Swing After Elastic Collision?
The discussion revolves around a pendulum problem involving two elastic balls in a collision scenario. Ball A, with mass m, is released and collides with stationary ball B, which has twice the mass. The conservation of momentum and energy principles are applied to derive the velocities of both balls post-collision. Ball A's velocity after the collision is calculated to be 1/3 of its initial velocity in the opposite direction, while ball B's velocity is 2/3 of ball A's initial velocity in the positive direction. Participants seek verification of their calculations and approaches to ensure accuracy before an upcoming exam.
Mdhiggenz
Urgent! Pendulum problem elastic collision
An elastic ball (A) with mass m is released from a horizontal position, connected via
a massless string to a rod. When the ball reaches the bottom, it collides with
another elastic ball (B) of twice the mass, aslo connected via a massless string to the rod.
How high can each ball swing, respectively? (The collision is total elastic.)
Assume the +x direction is to the right
a)What is the velocity of ball A after the collision? (5pt)
b)What is the velocity of ball B after the collision? (5pt)
c)How high will ball A swing relative to the bottom position? (5pt)
d)What is magnitude of the tension force (T) in the string connected to the ball A at the
moment right after the collision? (5pt)
A picture of the problem can be found at http://www2.fiu.edu/~leguo/Site/PHY2048_files/ExtraCredit2.pdf
M=Mtotal=3m
Va= initial velocity A
Vb= initial Velocity B
V1= final velocity A
V2= final velocity B
pi= initial momentum
pf= final momentum
ki = initial kinetic energy
kf= final kinetic energy
So what I first did was I wanted to find the initial velocity ( Va) before the collision.
To that I did: 1/2MVa^2=MgH
Va= √2gh
The collision is total elastic which means momentum and energy is conserved
Pi=pf
MaVa=Mav1+Mbv2
Im going to solve for v2:
MaVa-Mav1/Mb=v2
Plugging in known variables
m√2gh-mv1/2m=v2
m's cancel and you get
√2gh-v1/2=v2
Here is where I get confused my main problem lies with h. So I want to make that h cancel
since it is circular motion as the picture shows I try using uniform circular motion
g=Va^2/H
H= Va^2/g
I want to make sure if I am doing good so far. This is a problem that will be on my exam tomorrow so much help would be appreciated.
I'm attempting the same problem right now.
I took a different approach after final the initial velocity.
Since one object is stationary, I used the equations:
vaf = (ma - mb) / (ma + mb) * vai
vbf = (2ma) / (ma + mb) * vai
plugging in that gave me
(m-2m) / (m+2m) * √2gh
= -m / 3m * √2gh = -1/3 * √2gh
and
2m / m+2m * √2gh = 2m/3m *√2gh = 2/3 * √2gh
so the velocity of ball A after the collision is 1/3 the initial velocity in the opposite direction and the velocity of ball B is 2/3 the initial velocity of ball A in the +x direction
Can someone verify if this is correct?
and
That looks okay :approve:
