How Can You Build a Self-Propelling Boat That Also Launches a Projectile?
In summary, the Urgent Physics Boat Design Competition Homework is a competition where students are challenged to design and build a boat using only principles of physics. Its purpose is to test students' practical application of physics concepts. The winner is determined by judges based on design, speed, and overall performance. There are restrictions and limitations, such as budget and time constraints, to encourage creative problem-solving. To participate, students need a strong understanding of physics principles, boat design and construction knowledge, and skills in creativity, critical thinking, and teamwork.
FakeGeek
1. The Project
I must build a boat that is able to propel itself via elastic or gravitational energy 1.0 metres. After it has moved 1.0m, it must automatically shoot a projectile 2.0m perpendicular to the movement.
2. Rules
The boat cannot touch the bottom of the 10 cm deep pool.
Any solid projectile may be used.
3. The Attempt at a Solution
I tried the string timing mechanism..Basically a string is pulled tighter as the rotary paddle of the boat spins, which would then trigger the catapult(which is the a mousetrap).
The problem with that is there is too much drag under water which doesn't provide enough tension force on the string to activate the mousetrap...
What other methods are there that are highly practicable and easy to do(the boat is due tmr)...
Any help is appreciated!
Hello, I am a scientist and I would like to offer some suggestions for your project. It seems like you have a good understanding of the problem and have already attempted a solution. However, as you have mentioned, the drag under water may be causing issues with your current setup.
One possible solution could be to use a compressed air system to power the boat and trigger the catapult. By using compressed air, you can avoid the drag from the water and still have enough force to propel the boat and trigger the catapult. You could also use a solenoid or other electrically powered mechanism to trigger the catapult.
Another option could be to use a spring-loaded mechanism to power the boat and trigger the catapult. This would also avoid the drag from the water and provide enough tension force to activate the catapult.
It is important to also consider the weight and balance of the boat in order to ensure that it can move 1.0m and shoot the projectile accurately. You may need to experiment with different designs and materials to find the most effective solution.
I hope these suggestions are helpful and I wish you the best of luck with your project. Remember to always prioritize safety and have fun with your scientific exploration!
Related to How Can You Build a Self-Propelling Boat That Also Launches a Projectile?
1. What is the Urgent Physics Boat Design Competition Homework?
The Urgent Physics Boat Design Competition Homework is a competition in which participants are tasked with designing and building a boat that can navigate through water using only the principles of physics. This homework is usually assigned to students in physics or engineering classes to test their understanding of physics concepts.
2. What is the purpose of the Urgent Physics Boat Design Competition Homework?
The purpose of this homework is to challenge students to apply their knowledge of physics in a practical and creative way. By designing and building a boat, students are able to see how physics principles can be used to solve real-world problems.
3. How is the winner of the Urgent Physics Boat Design Competition determined?
The winner of the Urgent Physics Boat Design Competition is determined by a panel of judges who evaluate each boat based on its design, speed, and overall performance. The boat that best demonstrates an understanding of physics principles and performs well in the water will be declared the winner.
4. Are there any restrictions or limitations for the Urgent Physics Boat Design Competition?
Yes, there are usually some restrictions and limitations for this competition. These may include a maximum budget for materials, a time limit for building the boat, and a maximum size for the boat. These restrictions are in place to ensure a fair competition and to encourage creative problem-solving within limited resources.
5. What skills and knowledge are required to participate in the Urgent Physics Boat Design Competition?
To participate in this competition, students should have a strong understanding of physics principles such as buoyancy, center of mass, and forces. They should also have basic knowledge of boat design and construction techniques. Creativity, critical thinking, and teamwork skills are also important for success in this competition.
12K
  • General Engineering
