Use a graph to fine a number delta such that
  • Thread starter Thread starter afcwestwarrior
    Delta Graph
afcwestwarrior
/square rootsign 4x+1/ <.5 /X-2/ < delta
2 is x and 3 is y, 3 goes to 3.5 and 2.5, i need help with the absolute value of the square root sign 4x+1
Is this what you want?
\sqrt{4x+1} &lt; \frac{x-2}{2} &lt; \delta
O wait, last post I assumed the //'s were your grouping symbols. I think theyre absolulote value signs >.<
|\sqrt{4x+1}| &lt; \frac{|x-2|}{2} &lt; \delta
I hope that's what you want.
This is the second time you have posted this. Thanks to Gib Z for writing out the formula (you forgot the second "|" on the square root). But I still have no idea what "2 is x and 3 is y, 3 goes to 3.5 and 2.5" could mean! 3 doesn't "go" anywhere- it just sits there! And there is no "y" in your expression.
To Halls- Look abit closer :p its there.
To OP- I still have no idea what it is you want.
i should write it exactly
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
