Using complex numbers to represent distances
thomas49th
A man travels 12 kilometres northeast, 20 kilometres 30° west of north and finally
18 kilometres 60° south of west. Determine his position with respect to his starting point.
z = a + ib
|z|(cosx°+sinx°)
Well I thought about plotting these on a argand diagram and concatenating them with one another:
a = 12cos45 + i12sin45
b = 20cos30 + i20sin30
c = -60cos60 + -i60sin60 (im sure you could turn these into 30s)
I guessimated that the resulting vector should be somewhere in the top left quadrant?
Adding up the components and the cosine components and dividing one by the other, then taking the inverse tangent does no yeild the correct result.
Am I even going in the right direction?
Thanks
Thomas
Instead of writing the vectors in polar form as you have done, write them in rectangular form, and then add them. Polar form of vectors is useful if you need to multiply vectors; rectangular form is useful if you need to add or subtract them.
Hi thomas49th! :smile:
No, that's 30° north of east.
By rectangular do you mean Cartesian? :)
tiny-tim said:
Hi thomas49th! :smile:No, that's 30° north of east.
So
b = 20cos150 + i20sin150?
Same thing.
thomas49th said:
So
Your vector above is 30 deg. north of west. You want 30 deg. west of north.
Hi Thomas! :smile:
No, that's 30° north of west.
I don't understand why you're so bad at this exercise :confused:
what keeps making you get the wrong answer?​
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
