Using complex numbers to solve for a current in this circuit
42 replies · 4K views
GJ1
I am having trouble solving this equation, it is for an physics/electronics course
[50/(4+j3)(50)+100]x150
First I solved 4+j3, which I squared 4 and 3 to equal 16 and 9 then I added them to get 25 and then I got the square root of 25 = 5.
Then I plugged it back in to the equation.
[50/(5)(50)+100] x 150 to get 50/350x 150= 1/7(150)= 21.42. I've attached the correct answer.
GJ1 said:
Homework Statement:: I am having trouble solving this equation, it is for an physics/electronics course
Relevant Equations:: [50/(4+j3)(50)+100]x150
That doesn't look like an unambiguous mathematical expression.
Well, okay. That's the magnitude of that complex number.
I can't make any sense of what you've attached. What are you actually trying to do here?
Reply
The equation is for current in a circuit, it's in the picture that I've attached. It includes a complex number for the reactive properties in the current "4+3i" or 4+3j. When, I sive the equation for I1, I get 21.42, the actual number is 20 - 10j or 20-10i.
Okay, so the answer is a complex number, but you somehow got rid of the imaginary part and replaced the complex number ##4 + 3j## with ##5##?
GJ1 said:
But, how is the answer 20-10j
Does that mean that you got ##4 + j3 = 5##?
Note that ##|4 + j3| = 5##.
How would I add this complex number in this equation
It's difficult to help you, because the expression you wrote in the original post is unclear. Although, I think I can see from your calculations what you mean.
Basically, the answer is a complex number. It's a simplification of the complex number you started with. The key is to express ##\dfrac 1 {4 +j3}## as a complex number in standard (Cartesian) form.
The standard method for doing this is to use the complex conjugate:
$$\dfrac 1 {4 +j3} = \dfrac {4 - j3}{(4+j3)(4-j3)} = \dots$$Does any of that look familiar?
1) Make sure that you make your formulas unambiguous. Use parentheses; they are cheap.
Is that 50/( (4+j3)(50) )or ( 50/(4+j3) )(50)?
2) Often the first step in manipulating a fraction with a complex denominator ##1/(a+bj)## is to multiply both the numerator and denominator by the complex conjugate of the denominator to get ##(a-bj)/(a^2+b^2)##.
Reply
I have limited experience with complex numbers, this is the first that I've had to use them. If I see how this equation is solved, it will go along way in my understanding of them.
Reply
  • Skeptical
I doubt that!
Technically, we can't do your homework for you, and we expect you to have the required skills for the courses you are taking. You need to revise (or learn) Complex Numbers asap.
It's (50/(4+j3)(50)
PeroK said:
I doubt that!
Technically, we can't do your homework for you, and we expect you to have the required skills for the courses you are taking. You need to revise (or learn) Complex Numbers as see
FactChecker said:
This is invalid. Please be more careful with your parenthesis. Where is the ')' that matches the first '('?
[50/(4+j3)(50)+100]x150 This is the equation
GJ1 said:
It's (50/(4+j3)(50)
As already noted, this is ambiguous. Also, the parentheses aren't matched -- there are three left parens and two right parens.
PeroK said:
Which is simply 14+j3.
Assuming that the ambiguous expression above is ##\frac {50}{(4 + j3)50}##. As written, it could be interpreted as ##\frac{50}{4 + j3}\cdot 50## or ##\frac{2500}{4 + j3}##.
That is not an equation. An equation always has an = symbol somewhere in the middle.
Babadag said:
50/[(4+3j)x50+100]x150=20-10j
How did the get 20-10j as the answer
