Using integration to find depth
  • Thread starter Thread starter jackscholar
    Depth Integration
To determine the depth of a sinkhole after a mobile phone drops, the total time of 8.5 seconds must be divided into the time of free fall and the time for sound to travel back up. The acceleration due to gravity is 9.8 m/s², and the velocity of sound is 334 m/s. The approach involves calculating the fall time using the equation y = 0.5 * a * t², where 't' is the total time minus the time for sound to return. By substituting the appropriate values and solving for depth, the correct relationship between fall time and sound travel time can be established. This method effectively integrates both the free fall and sound travel components to find the hole's depth.
jackscholar
Your mobile phone drops down a sinkhole. You hear it hit the bottom 8.5 seconds later. How deep is the hole?
Assume there is no air resistance
velocity of sound 334m/s
gravity 9.8m/s
I tried integrating the equation using just the acceleration; however, I believe that the velocity of sound needs to be incorporated aswell. So I started with a(t)=9.8 then integrated to get 9.8t +c, then I made t=0 v=0 and so c=0 and integrated again to get 4.9t^2 +c, I'm not sure where to go from here.
hi jackscholar! :smile:
do it the other way round …
find the time it takes to fall a distance x, then add the time for the sound to return from that distance,
then put that equal to 8.5, and solve for x :wink:
all I can think of is 8.5=9.8x + ?? for some reason I keep going back to 8.5=9.8x+x/334
what is the time taken to fall a distance x (from rest)?
I'm sorry but i have absolutely no idea
I shall sleep on it. Thank you for all your help, as always you've given me something to think about.
Hint:
Determine the time for the sound to go from bottom of pit to top. If depth is y then
dt = y/334 seconds
Use free fall equation to determine depth of hole.
y = 0.5 * a * t^2 where
t = total time minus the time for the sound to get from bottom to top
a = 9.8 m/sec^2
