Using Kinematics to find the Distance of an object dropped from rest
  • Thread starter Thread starter garcia1
    Kinematics Rest
To find the height h from which the stone is dropped, the time for the stone thrown upwards must first be calculated. The initial speed of the thrown stone is 44.1 m/s, and it will take time to reach its peak and then fall back down. Using kinematic equations, the total time can be determined, which is then applied to find the distance h for the dropped stone under gravitational acceleration of 9.8 m/s². Previous attempts to solve for h using incorrect assumptions about the motion of both stones led to erroneous results. The correct approach involves calculating the time of flight for the thrown stone and using that to find the distance fallen by the dropped stone.
garcia1
A stone is thrown straight up from the ground
with an initial speed of 44.1 m/s . At the same
instant, a stone is dropped from a height of
h meters above ground level. The two stones
strike the ground simultaneously.
Find the height h. The acceleration of
gravity is 9.8 m/s2 .
Answer in units of m.
Kinematics equations, such as V^2 = Vo^2 + 2ax, V = Vo +at, x = Vot +1/2at^2, and x = 1/2(Vo +V)t
I first thought that by plugging the known variables, with V as 0 m/s, into V^2 = Vo^2 +2ax, solving for x. I got x=99.225. This was wrong. I then re-read the statement, thinking that I needed to double my answer, since the object thrown up also had a downward portion before it hit the ground with the falling object. This was x = 198.45m. This was also wrong.
First, you need to find the time it takes for the rock thrown upwards to hit the floor again. Using that time, you know that the second rock covered a distance of h in the same amount of time under uniform acceleration.
