Using Laplace Transforms to Solve PDE
ColdFusion85
Use the Laplace transform to solve
\frac{\partial^2 y }{ \partial t^2 } = c^2 \frac{ \partial^2 y }{ \partial x^2 } for x>0, t>0
y(0,t) = t, for t>0
y(x,0) = 0, \frac{\partial y(x,0) }{ \partial t } = A, for x>0So I used the Laplace transform of a derivative, along with the initial conditions to get the PDE in the form
\frac{\partial^2 Y }{ \partial x^2 } = \frac{s^2}{c^2} Y - \frac{A}{c^2}
However, I am not sure how to solve this. I know if the A/c^2 wasn't there it would just be
Y(x,s) = A(s)e^{\frac{s}{a} x} + B(s)e^{-\frac{s}{a} x}
and since Y must be finite for all s because the Laplace transform of a finite function is finite, A(s)=0, leaving just
Y(x,s) = B(s)e^{-\frac{s}{a} x}
and my notes from class tell me how to proceed from here. My problem is I don't know how to generate a form of the solution to my problem that I arrived at above. Can anyone help me proceed from here?If it is any help, the book tells me the final answer should be:
y(x,t) = At + (1-A)(t-\frac{x}{c})H(t-\frac{x}{c})
where H is the Heaviside function
You are using the Laplace transform on partial differential equations and don't know how to handle a non-homogeneous linear equation with constant coefficients? It must have be been a long time since you took an introductory course in ordinary differential equations!
Use "undetermined coefficients" with y= C, constant. Put that into the equation to see what C must be in order to satisfy the equation.
This doesn't work. If I guess y=C, then we find that C=A/s^2. Y(0,s) = t, and taking the Laplace transform if this gives us 1/s^2, meaning A=1. So Y(x,s) = 1/s^2 and therefore y(x,t) = t. This isn't even close to the answer in the book.
Nevermind, I solved the problem. It involves an exponential term plus an A/s term prior to taking the inverse transform to arrive at the solution. Guessing y=C wasn't the correct method. Thanks anyway though
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
