Usual and taxicab metric topologies
  • Thread starter Thread starter Unassuming
    Metric
Unassuming
I am trying to show that an "epsilon ball in the taxicab metric" can be contained in a "epsilon ball in the usual metric".
Let "Up" be a taxicab ball, and "Ud" be a usual metric ball.
How can I show that Up( (x,y) , e ) is a subset of Ud( (x,y), e ) ?
I have drawn the picture and I understand how the taxicab ball is inside. It is a diamond that touches the usual ball on each of the diamond's four corners and is less than everywhere else.
How can I show this algebraically?
I actually figured this out from a previous thread on this forum. Yippee.
I need to show the reverse is true though and I can't it out. I need to show that we can construct a taxicab metric that contains any usual epsilon-ball.
Just use geometry again. Now you have a circle inscribed in a diamond instead of vice versa. Neither one is that hard.
I have to use algebra... for instance, for the first part I said,
Since
|x-a| =\sqrt{(x-a)^2} \leq \sqrt{ (x-a)^2 + (y-b)^2 } = \varepsilon
and
|y-b| = \sqrt{(y-b)^2} \leq \sqrt{ (x-a)^2 + (y-b)^2 } = \varepsilon
then
|x-a| + |y-b| \leq 2\varepsilon
Let
k= \frac{1}{2}
Then
k(|x-a| + |y-b|) \leq \varepsilon = \sqrt{ (x-a)^2 + (y-b)^2 }
Well, I don't know if you can see that latex but this is what I did,
Since |x-a| =\sqrt{(x-a)^2} <= sqrt{ (x-a)^2 + (y-b)^2 } = e
and |y-b| = \sqrt{(y-b)^2} <= \sqrt{ (x-a)^2 + (y-b)^2 } = e
then |x-a| + |y-b| <= 2e
Let k= 1/2. Then k(|x-a| + |y-b|) <= e = \sqrt{ (x-a)^2 + (y-b)^2 }
Yes, k=1/2 works fine.
Is showing the other way similar? I am not getting anywhere. You said use the traingle inequality. Are we still looking for a constant?
Just write down the triangle inequality for the three points (a,b), (x,y) and (x,b).
