UV and harmful gases formation at aging test chamber
The discussion centers on the potential for ozone formation and harmful gases in a UV aging test chamber that uses high-pressure mercury discharge lamps. The chamber emits UVA, UVB, and minimal UVC radiation. It is noted that high-pressure mercury lamps can generate ozone, raising concerns about air quality within the chamber, especially since personnel must enter and exit for item collection. The participant seeks clarification on the conditions necessary for ozone formation, specifically the role of nitrogen oxides (NOx), volatile organic compounds (VOCs), and the specific wavelengths of UV radiation involved. It is highlighted that UV radiation below 200 nm, particularly around 185 nm, can dissociate oxygen molecules (O2) to form ozone (O3). The participant also references a document that provides insights into UV lamp applications and their photochemical effects.
Stroj
Hello!
At work we have an UV aging test chamber that produces around 140 W.m^-2 UVA 15 W.m^-2 UVB and less then 1 W.m^-2 of UVC.
The chamber is big, we have to go in and out to collect the items.
Is it possible to have ozone formation or other harmful gases inside the chamber?
Chemistry news on Phys.org
If you use high pressure mercury discharge lamps, then you are generating ozone.
Thanks for your answer. I will see tomorrow what type of lamps are used.
Meanwhile, following your answer I found this document:
http://cdn.intechopen.com/pdfs/3462...cations_an_evaluation_of_pulsed_radiation.pdf
that helped me to understand better about lamps for UV applications.
Nevertheless, I still have some questions:
1. Ozone formation at ground level needs NOx and VOC and UV radiation (any wavelength?)
2. UV radiation bellow 200 nm wavelength (or only at 185 nm ?) can split O2 leading to he formation of O3
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
