UV Light Wavelengths Reaching Earth's Surface
In summary: Ultraviolet (UV) radiation is electromagnetic radiation with wavelengths shorter than visible light, but longer than soft X-rays. It is divided into near UV (380-200 nm) and extreme or vacuum UV (200-10 nm). UVA (380-315 nm), UVB (315-280 nm), and UVC (280-10 nm) are commonly used subdivisions. The Sun emits UV radiation in all three bands, but due to absorption in the ozone layer, most of the UV reaching the Earth's surface is UVA. Some UV is absorbed by the atmosphere, while others are re-emitted. This is due to resonance, not size.
Shawnzyoo
105
Does anyone know the range of the wavelengths of the UV light that reaches the Earth (ground)?
Science news on Phys.org
Ultraviolet (UV) radiation is electromagnetic radiation of a wavelength shorter than visible light, but longer than that of soft X-rays. It can be subdivided into near UV (380–200 nm wavelength) and extreme or vacuum UV (200–10 nm). UV wavelengths are also often subdivided into UVA (380–315 nm), also called Long Wave or "blacklight"; UVB (315–280 nm), also called Medium Wave; and UVC (280-10 nm), also called Short Wave or "germicidal".
The name means "beyond violet" (from Latin ultra, "beyond"), violet being the color of the shortest wavelengths of visible light.
The Sun emits ultraviolet radiation in the UVA, UVB, and UVC bands, but because of absorption in the atmosphere's ozone layer, approximately 99% of the ultraviolet radiation that reaches the Earth's surface is UVA (380–315 nm). UVC is partially responsible for the generation of ozone as well, and most of the remaining 1% is extream/vacuum UV (200-10 nm)
Why would the UVA light enter the atmosphere while UVC interacts with it. To me, it would make sense if it was the other way around. The larger wavelength ultraviolet light (UVA) would not make it through since the distance between molecules in the atmosphere is not enough to let the light through, while the UVC light, which is of a smaller wavelength, should enter (just like sunlight-blue enters while red doesn't). Is it bcause the UVS wavelength is soo small that the waves actually interact with particles in the atmosphere and cannot pass by them?
Nenad,
Size is not the dominant mechanism, resonance is (absorbtion/emission). Some UV's are absorbed (blocked) by the atmosphere, while others are re-emitted (enter). Red does enter, otherwise we could not see red here.
TRoc
Related to UV Light Wavelengths Reaching Earth's Surface
What is UV light?
UV light, or ultraviolet light, is a type of electromagnetic radiation that has a shorter wavelength and higher energy than visible light. It is invisible to the human eye, but can be seen by some animals, such as birds and insects.
What are the different wavelengths of UV light?
UV light is divided into three categories based on its wavelength: UVA (320-400 nanometers), UVB (290-320 nanometers), and UVC (100-290 nanometers). UVA has the longest wavelength and is the least damaging, while UVC has the shortest wavelength and is the most harmful to living organisms.
How does UV light reach Earth's surface?
The sun emits UV light, which travels through the Earth's atmosphere and reaches the surface. Some of the UV light is absorbed or scattered by the atmosphere, but a significant amount reaches the surface, especially in areas with little cloud coverage.
What are the effects of UV light on living organisms?
UV light can have both positive and negative effects on living organisms. It is necessary for the production of vitamin D in humans, but overexposure can cause skin damage and increase the risk of skin cancer. UV light can also affect the growth and development of plants and can be harmful to some marine organisms.
How does the amount of UV light reaching Earth's surface vary?
The amount of UV light reaching Earth's surface can vary depending on several factors, such as the time of day, season, location, and atmospheric conditions. For example, UV light is strongest during midday and in the summer, and it is weaker in areas with higher cloud cover or air pollution. Additionally, the Earth's ozone layer plays a crucial role in filtering out harmful UV radiation, so its depletion can result in higher levels of UV light reaching the surface.
10K
  • Materials and Chemical Engineering
