V/f speed control of 3 phase Induction motors
The discussion focuses on the torque proportionality equations for 3-phase induction motors when maintaining a constant voltage-to-frequency (V/f) ratio. The participants debate whether torque is proportional to slip multiplied by frequency or solely to slip. The correct answer to a GATE EE paper problem regarding the speed of a 4-pole induction motor at 30 Hz, given a constant load torque, is confirmed to be 864 rpm, aligning with the equation that includes slip and voltage. The consensus is that maintaining constant flux requires the same slip frequency for the same torque.
  • Understanding of 3-phase induction motor operation
  • Knowledge of voltage-to-frequency (V/f) control methods
  • Familiarity with torque equations in electrical machines
  • Basic principles of slip in induction motors
  • Study the impact of V/f control on induction motor performance
  • Learn about torque equations in 3-phase induction motors
  • Explore the concept of slip and its effect on motor speed
  • Review GATE EE previous papers for similar problems
Electrical engineers, students preparing for GATE EE, and professionals involved in motor control and performance optimization.
makkena
When the voltage / frequency is maintained constant in 3 phase Induction motor i.e. flux is maintained constant by changing the voltage and frequency in same proportion, What is the torque proportionality equation.
Whether
Torque is proportional to Slip X Frequency
or
Torque is proportional to only Slip ?
Based on the above equation I need to solve a question given in GATE EE paper 2006.
The speed of a 4-pole induction motor is controlled by varying the supply frequency while maintaining the ratio of supply voltage to supply frequency (V/f) constant. At rated frequency of 50 Hz and rated voltage of 400 V its speed is 1440 rpm. Find the speed at 30 Hz, if the load torque is constant.
(A) 882rpm
(B) 864 rpm
(C) 840 rpm
(D) 828 rpm
GK publishers Gate previous papers Book is given the answer as 864 rpm. This answer will come if we use T proportional to Slip.
But I saw in some textbooks Torque proportional to slip X (square of Voltage) / f.
From this eauation when V/f is constant, T should be proportional to slip X Voltage i.e. T proportional to slip X frequency.
I am confusing on this which Torque equation to follow when V/f is maintained constant.
Please help me in this.
Thanks
If the flux is maintained at the same level then for the same torque you require the same slip frequency. So the answer is "C".
thanks uart.
  • · Replies 31 ·
