Comparing Vacuum Capability of Pump Models WELCH 1375 & PFEIFFER DUO65
The ultimate pressure of a vacuum pump indicates its vacuum capability, with the WELCH 1375 (1 x 10^-4 Torr) outperforming the PFEIFFER DUO65 (2 x 10^-3 Torr) in terms of vacuum quality. Both pumps have the same speed of 35 CFM, but the choice may also depend on other factors like price, size, power consumption, noise, and durability. The speed versus ultimate pressure curve suggests that while a higher CFM allows for faster pump-down times, a lower CFM pump can still achieve the same ultimate pressure if time is not a constraint. For applications requiring frequent access to the vacuum chamber, a faster pump may be more practical. Ultimately, the selection should align with specific needs and operational requirements.
vultac
Dear All,
Appreciate if you can guide me on understanding the ultimate pressure of vacuum pump.
I have two models for review.
One has ultimate pressure of 1 x 10^-4Torr the other has 2 x 10^-3Torr.
From this can it be said that the vacuum capability of the first pump (1 x 10^-4) larger range? is better than the second pump?
Both has speed 35CFM.
Model 1 Pump WELCH 1375
Model 2 Pump PFEIFFER DUO65
Thanks for your help.
These specs indicate coarse vacuum pumps, where the quality of the ultimate vacuum is not that critical.
My guess is other parameters, such as price, size, power use, noise or durability are also factors in the purchase decision.
If those don't matter in your case, then yes there is a factor of 20 difference in the vacuum quality produced by the two pumps.
Hi, thanks for replying.
What is the signifance of the curve for the Speed vs the Ultimate Pressure. What does the curve implies?
ie if i found a machine that is running at 20CFM (15 less) but having 1 x 10^-4torr. is that ok?
The pump will not exhaust the volume to the ultimate pressure immediately,
A higher CFM rating unit will pump down a volume faster than the lower rated pump, but if you can afford the time, the lower CFM rated pump will serve equally well.
Do note that if you have any sort of a setup where you need to repeatedly access some element that is operating when in vacuum, it can be a real pain to wait for the pumpdown each time you adjust something.
What drives the need for a vacuum?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
12K
