How to solve cross products in physics problems?
The discussion centers on solving cross products in physics problems using the formula for vector cross products. The user expresses uncertainty about applying the formula to their specific vectors, particularly regarding matrix dimensions. They provide their calculated results for two cross products, which are confirmed as correct by another participant. The conversation clarifies that the formula is indeed applicable to the vectors presented, dispelling confusion about matrix types. Overall, the user successfully computes the cross products and receives validation for their work.
uchicago2012
I'm solving a physics problem using cross products and I think I might be doing the cross products wrong
I'm using the formula:
a cross b = (a2b3- a3b2)x + (a3b1- a1b3)y + (a1b2- a2b1)z
where a1 = ax, a2 = ay, a3 = az, etc.
I don't know if this formula should be used on matrices like these, esp. the second cross product since its not 3 * 3 or 2 * 2 matrix, which I'm pretty sure is all that the formula is intended for. I had to get off wikipedia because my physics book doesn't go into how to solve cross products and I don't have any algebra books around.
The cross products are:
(2.5x - 4.3y + 5.1z) cross (-2.4x + 8.0y - 2.6z)
and
(2.5x - 4.3y + 5.1z) cross (10x + 14y)
I got
(-29.62x - 5.74y + 9.68z) for the first one
and
(-71.4x +51y + 78z) for the second one
What matrices? What 3x3 and 2x2? What are you talking about? :confused:
This is the formula for the cross product of two vectors, each of which has 3 components.
and
I got
and
The first one that you did checks out fine for me.
The second one should be (-71.4x + 51y 78z). So yes, you got them both right.
