pivoxa15 said:
Is the value of a function defined as the limit as x approaches each value in the domain of f(x)?
What happens if at a specific x, you have f(x)-> 0/0? is there usually a limit for which f(x) approaches in this situation?
Your original question doesn't make sense. If x is in the
domain of a function f, then, by definition of "domain", the value of the function, f(x), is defined there. Do you mean the
limit of the function? It is quite possible for a function value to be defined and the limit not exist there.
For example, f(x)= 0 if x is rational and 1 if x is irrational is defined for all real numbers but the limit does not exist anywhere.
pivoxa15 said:
So f(0)=1 when f(x)=x/x so 0/0 in this case equals to 1.
NO! If f(x)= x/x then its domain is "all real numbers except 0". f(0) is not defined. On the other hand, its limit as x goes to 0 IS defined and is 1. This is an example in which the limit is defined at a "limit point" of the domain that is not in the domain.
pivoxa15 said:
But 0/0 can in some situations like x/x=1 where you take the limit as x->0. If you define any function with the limit as x approaches each specific point in the domain than you can define situations like x/x when x=0 couldn't you?
NO again! You are confusing the limit with the value of the function. That's why your Calculus teacher is always careful to say things like
\frac{x^2- 4}{x-2}= x+ 2
as long as x is not equal to 2.
y= x+ 2 is defined for all x. Its graph is a straight line. (x
2-4)/(x-2) is not defined at x= 2. Its graph is a straight line with a hole at (2, 4).
