Value that gives more than one stationary point
  • Thread starter Thread starter maxim07
    Point Value
13 replies · 2K views
maxim07
What value of z makes the curve have more than one stationary point
f(x) = 2x^3 -12x^2 + zx + 30
Here is my attempt at a solution
I don’t know where to go from here, as the equation is a quadratic it will have two solutions which means there will be two stationary points, but I don’t know how to solve for z.
Does a quadratic always have two solutions?
maxim07 said:
Not if both brackets are the same
I have no idea what you mean by that. What brackets?
  • Love
  • Haha
That is only guaranteed if you allow complex solutions. When the problem expects only real solutions, the quadratic formula must have non-negative numbers inside the square root. That should allow you to get the restrictions on z.
I mean sometimes if you factor a quadratic the two bracketed terms you end up with are the same so you only have one solution
Can you always factorise a quadratic? What about ##x^2 + 1##?
You need to use the quadratic formula. That will give you the factors, whether they are real, complex, integer, irrational, etc.
using the fact that the term under the square root can not be negative, this is what I get
So to summarize, there will be two stationary points if z < 24.
What happens if z = 24? Or if z > 24?
Comment - the usual way of writing the derivative of f at a value x is f'(x), not f(x)'. IOW, the "prime" symbol (an apostrophe) goes immediately after the function name.
If z = 24 you get sqrt(0) , if z>24 you get a negative in the square root, neither of which are possible
No, both these cases are possible. If z = 24, there is only one stationary point. If z > 24, there are no stationary points. In the latter case, this means that the graph of ##f(x) = 2x^3 - 12x^2 + zx + 30## is always increasing; i.e., has no points at which the tangent line is horizontal.
So if z =24 we get √0 so there is only one x solution and so one stationary point, if z > 24 we get √- so there are no solutions and no stationary points
Yes, on the real line. When you start to talk about complex numbers, there are complex solutions for the square root of negative numbers, but that is another subject.
