Understanding Franklin's Wheel: A Van de Graaff Experiment
The Franklin's wheel experiment involves sharp points that create a strong electric field, ionizing nearby air and generating charged ions. These ions are repelled by the electric field, producing an effect known as electric wind, which propels the wheel. The direction of the wheel's rotation, whether counterclockwise or otherwise, is determined by the orientation of the sharp points. Understanding this mechanism clarifies the wheel's movement and the principles of electrostatics at play. This experiment effectively demonstrates the interaction between electric fields and charged particles.
amirali75
Hey guys,
I'm new to this forum so I'm sorry if I posted in the wrong thread. So we did these experiments with van de graaff and I almost understood all of them except what seems to be "Franklin's wheel" experiment. I know for one thing that the air near the sharp points are ionized but I don't get why it actually turns and also why counterclockwise?
Any help is appreciated.
The sharp points create an intense local electric field which induces a charge on nearby atoms of air (oxygen, nitrogen etc.) by 'sucking' all the opposite charges away. The charged atoms (now called ions) are repelled by the field and shoot away like the exhaust of a jet engine. (This is called electric wind)
The reaction of that jet is what drives the wheel around.
Which way it turns depends on which way you have the points.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
