Vanadium Content in 4330V Steel
  • Thread starter Thread starter Lazorbeam
    Steel
The discussion centers on the appropriate vanadium content in 4330V steel, which ranges from 0.05% to 0.15%. There is a divide among suppliers regarding the optimal percentage, with some advocating for the lower end and others for the higher end. Vanadium enhances the steel's properties through dispersion-strengthening and affects grain structure, with a common preference for a nominal content around 0.07%. Heat treatment and working processes also significantly influence the steel's microstructure. Testing samples with varying vanadium levels could provide insights into their impact on tensile strength, hardness, and impact strength.
Lazorbeam
Hi all,
Hope I'm posting this in the right forum! I have some questions with regards to 4330V steel. This is a Vanadium-modified 4330 steel, with Vanadium contents ranging from 0.05 - 0.15%.
I work for a company that builds tools for the mining industry, and our steel suppliers are divided on the issue of Vanadium content. Some say it should be near the 0.05% minimum, others say it should be at or near 0.15%.
The problem is that nobody here understands the impact of Vanadium in this steel and how (if at all) it affects its properties.
Any input?
Lazorbeam said:
Hi all,
Any input?
Vanadium is a carbide and nitride former, so it strengthens steels by dispersion-strengthening. It also affects grain structure.
It seems that a number of suppliers prefer a nominal content of about 0.07 or mid range of 0.05 to 0.10%. There could be synergistic effects with Cr and Mo contents.
http://www.westyorkssteel.com/alloy-steel/oil-and-gas/aisi-4330v/
http://www.westyorkssteel.com/files/aisi-4330v.pdf
http://customer.cartech.com/assets/documents/datasheets/4330+V.pdf
http://www.encoremetals.com/docs/product_manual/Section%202.0%20Alloy%20Steels.pdf
It is also important to consider the heat treatment and hot/cold working which will affect the microstructure.
Effects of V on steels:
http://vanitec.org/wp-content/uploads/2011/09/Vanadium-in-Medium-and-High-Carbon-Steels.pdf
http://www.hsla-v.org/assets/documents/Effect_of_Vanadium.pdf
http://www.kau.se/sites/default/files/Dokument/subpage/2010/02/21_269_287_pdf_18759.pdf
https://online.tugraz.at/tug_online/voe_main2.getvolltext?pCurrPk=32837
http://www.archivesmse.org/vol33_2/3321.pdf
http://steel.keytometals.com/Articles/Art182.htm
http://steel.keytometals.com/Articles/Art85.htm
It's best to look at different sources.
One might try to obtain some samples with one on the low end of the V range and one on the high end and compare tensile strength, hardness, and impact strength.
Likes mfb
