Variation of the Christoffel Symbols
Breo
So, it is defined that:
Γλμυ = Γλμυ + δΓλμυ
This makes obvious to see that the variation of the connection, which is defined as a difference of 2 connections, is indeed a tensor.
Therefore we can express it as a sum of covariant derivatives.
δΓλμυ = ½gλν(-∇λδgμν + ∇μδgλν + ∇νδgλμ)
However, I do not know how to make this step. Help?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Γλμυ = Γλμυ + δΓλμυ
I think you might want to go over the equations you wrote down.
http://ned.ipac.caltech.edu/level5/March01/Carroll3/Carroll3.html
If you were looking for the anti-symmetrical properties of Christoffel Symbols (ie torsion) and the commutation relations of the covariant derivative...here is a link:
http://www.aias.us/documents/uft/a42ndpaper.pdf
A simple way to do it is to apply the variation directly to the solution of the Christoffel symbol. You'll get partial derivatives of variations of the metric, but you know the result should be gct-covariant. So you can replace the partial derivatives by covariant ones. If you're not sure about this (think it through carefully!), you can check it explicitly, but that's a bit tedious.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
