Various Problems for Precalculus Exam, Unit 2
The discussion focuses on solving three precalculus problems involving exponential and logarithmic equations. For the first problem, the equation x^2*e^x + x*e^x - e^x = 0 is factored, leading to a quadratic solution, with clarification needed on handling the e^x term. The second problem involves connecting two logarithmic equations to find log_xy, suggesting substitution for clarity. The third problem requires evaluating log_b(64/49) using properties of logarithms, with participants guiding each other through the necessary steps. Overall, the thread emphasizes collaborative problem-solving and clarification of logarithmic properties.
jacksonpeeble
9.e. Solve the equation for x: x2*ex+x*ex-ex=0
19. If logxa=0.578 and logay=1.161, what is the value of logxy?
26. Use the fact that logb4=x and logb7=y to evaluate logb(64/49).
9.e. x2*ex+x*ex-ex=0
19. logxa=0.578 and logay=1.161
26. logxa=0.578 and logay=1.161
9.e. Factored equation so ex(x2+x-1), then plugged into quadratic equation so \frac{-1+-\sqrt{1^{2}-4*1*-1}}{2*1} which equals \frac{-1+-\sqrt{5}}{2}. However, I'm wondering exactly what to do with the initial ex that I factored out - the answer key we were provided with does not include it at all, but I assumed that we would pin it in front of the equation so that our final answer is ex*\frac{-1+-\sqrt{5}}{2}.
19. I remember doing these and that the solution is fairly obvious, I just forget what it is.
26. Sorry, this is one where I have no idea.
For the first problem, think zero product property. You've already found two values that will yield a zero. Now, when does e^x equal 0?
The solution to the second problem can be obtained by noting a = x^0.578 and y = a^1.161
Assuming the desired answer need be expressed in terms of x and y, use the properties alog(x) = log(x^a), log(a/b) = log(a) - log(b).
Thanks for the reply!
Ok, so I was fairly accurate with #9.
For #19, I understand that - from the revised equations, how are we supposed to connect them into a single solution?
#26 is still up for grabs ;-)
Yeah, since e^x is never zero, you already had the two solutions.
For 19 try a simple substitution.
Alright, 64 = 4^3 and 49 = 7^2. Therefore, log(64) = 3x and log(49) = 2y. Can you take it from there?
The first one is correct since ex can never be zero. There are 2 solutions.
2nd one:
\frac{log_ay}{log_ax}=log_xy
\frac{1}{log_ax}=0.578
log_ax=\frac{1}{0.578}
Now divide log_ay with log_ax
3nd one:
3log_b4=3x[/itex]<br /> <br /> log_b64=3x[/itex]&lt;br /&gt; &lt;br /&gt; 2log_b7=2y[/itex]&amp;lt;br /&amp;gt; &amp;lt;br /&amp;gt; log_b49=2y[/itex]&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; log_b(64/49)=log_b64-log_b49&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; Now just substitute.&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; Regards.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
